P0850 CEL Code
Old Aug 28, 2008 | 08:28 AM
goliat11's Avatar
P0850 CEL Code
Hi Guys
I have a 2005 manual trans RX8 and has the P0850 Neutral switch input circuit open. I found the tech note on what to do but I don't know wher the neutral switch is located or if someone else had this prob and can help me.
THANKS
Old Aug 28, 2008 | 11:03 AM
Neutral switch is located on the transmission
Next time, Search before u post. stop asking people to do homework for you. afterall its your car, not ours.
Old Aug 29, 2008 | 12:38 AM
left rear upper side of the main trans housing, has wires running to it
Old Mar 15, 2009 | 01:54 PM
PRX8's Avatar
Any pictures or diagrams
Old Mar 17, 2009 | 03:46 PM
I'm getting the P0850 neutral switch CEL. Also occurring at the same time is the cruise control can be turned on, but won't engage. I suspect it's because of the neutral switch, but not 100% sure. Replaced the switch with the newest part, CEL came back again.
The car idles and runs perfectly. I also had the trans rebuilt just prior to having the problem (by a non-Mazda trans shop). My worst case fear is that whatever engages/disengages the switch in the trans may not be aligned properly.
It doesn't help that the Harrison CanPOScan has gone flakey on me again
https://www.rx8club.com/showpost.php...69&postcount=7
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Evan Gray
Sep 26, 2015 12:30 PM
