What tranny fluid
Old Aug 27, 2008 | 01:55 PM
Transam kid 01's Avatar
The anti-ricer
What tranny fluid
New clutch and flywheel in (stage 1 from SPEC/BHR). So what fluids should I change from stock form
Old Aug 27, 2008 | 01:58 PM
chrism's Avatar
Misfit Moderator TnC
search n00b!
Old Aug 27, 2008 | 01:59 PM
Redline
Old Aug 27, 2008 | 02:04 PM
dillsrotary's Avatar
jersey fresh
def redline
Old Aug 27, 2008 | 02:17 PM
Blueline.
Old Aug 27, 2008 | 02:18 PM
back of your manual will list what weight Trans. fluid to use.
Old Aug 27, 2008 | 02:19 PM
Brettus's Avatar
Boosted Kiwi
Originally Posted by nycgps
Blueline.
straightline
Old Aug 27, 2008 | 02:20 PM
NgoRX8's Avatar
redline mt-90 for trans
redline 75w90 for diff
Old Aug 27, 2008 | 02:30 PM
Originally Posted by Brettus
straightline
I used blueline and noline. but I think searchline is the best
Old Aug 27, 2008 | 02:31 PM
Nothing beats Royal Aqua
Old Aug 27, 2008 | 02:32 PM
chancejat's Avatar
Drive it like u stole it!
royal purple.....hahahaa.....oh wait thats a real product......
Old Aug 27, 2008 | 02:33 PM
NgoRX8's Avatar
searchline? isn't that filled with like alphabet soup?
Old Aug 27, 2008 | 02:46 PM
yeah ....
Old Aug 27, 2008 | 07:39 PM
must ... not ... respond ...
Old Aug 27, 2008 | 07:53 PM
He's on a post binge....
Old Aug 27, 2008 | 08:07 PM
chrism's Avatar
wow.....lol....search tonnage....actually the search for this query is a bit convoluded because i tried too...from what i gathered redline seems to be the most liked and rp breaks stuff after a while or makes **** worse.....
Old Aug 27, 2008 | 08:24 PM
Im_DANomite's Avatar
I love GOOOLD
dexron III...don't listen to these guys. they're just trying to throw you off.
Old Aug 27, 2008 | 10:49 PM
rofl dexron III ....
Old Aug 28, 2008 | 09:05 AM
jersey fresh
Also, i use to grind gears with the lighter fluids so I went with Shockproof by redline.
Old Aug 28, 2008 | 10:30 AM
Charles R. Hill's Avatar
Owner of BHR
I used to use "Hairline" but I lost it.......
Old Aug 28, 2008 | 10:33 AM
chrism's Avatar
redline it is.....and how much for the diff and trans for a drain and flush?......doing this in a few with TAkid and need to know....thanks guys
Old Aug 28, 2008 | 11:58 AM
RK's Avatar
RK
It's Not Easy Being Green
http://www.hi-impact.org/ryang/modif...x8_fluids.html
The manual transmission uses two quarts of Redline MT-90 oil
The rear limited slip differential uses two quarts of Redline 75W90 GL5 oil.
Old Aug 28, 2008 | 02:21 PM
Brettus's Avatar
Boosted Kiwi
This thread was going places and you just f***d it up - geeez thanks
Old Aug 28, 2008 | 02:56 PM
NgoRX8's Avatar
the only place it was going was to the lounge. hahaha...
yea chris, 2 quarts of each will do as long as there's no spilling. haha
Old Aug 28, 2008 | 03:21 PM
MazdaManiac's Avatar
1.5 quarts of MT-90 and .8 quart of MTL.
