Is +60mm offset too much for the rx-8?
Old Aug 26, 2008 | 12:10 AM
delhi's Avatar
Grand Chancellor
I'm looking to get some used mazda6 17" rims and they look to have +55 - +60mm offset. I know that stock rx-8s are +50mm. Would that mean the mazda6 rims might be too much?
Old Aug 26, 2008 | 12:13 AM
NgoRX8's Avatar
stock 6 wheels? it'll be sucken in a lot more. I wouldn't do it. Most 6 owners would take our wheels, why take theirs?
Old Aug 26, 2008 | 12:17 AM
TopGear8's Avatar
mkuhnracing.com
a narrower wheel mean less stability on the road... i wouldnt do it.
Old Aug 26, 2008 | 12:20 AM
delhi's Avatar
Grand Chancellor
OK OK... let me preface the question as in, using the stock 6 rims for winter duties. Will it fit as theirs are around +55 - +60.
Old Aug 26, 2008 | 12:23 AM
NgoRX8's Avatar
what's the wheel width?
Old Aug 26, 2008 | 12:25 AM
delhi's Avatar
Grand Chancellor
7" wide.
215/50/17 full spec.
thx.
Old Aug 26, 2008 | 12:35 AM
NgoRX8's Avatar
it should fit fine.
Old Aug 26, 2008 | 12:54 AM
inboard clearance should be fine, but you need to be very concerned about brake caliper clearance with the spokes, especially on the front
offset alone can't provide this answer
Old Aug 26, 2008 | 11:49 AM
Peppy@kacework's Avatar
Hoarder of RPF1's
You could always use a 5-10mm spacer to give more clearance for the caliper.
Old Aug 26, 2008 | 11:53 AM
NgoRX8's Avatar
he just needs to make sure the spokes don't touch the caliper. all depends on the spoke design.
Old Aug 26, 2008 | 12:41 PM
spoke hitting caliper....BAD.
Old Aug 26, 2008 | 02:39 PM
delhi's Avatar
Grand Chancellor
Well if that's the case I might as well just get mazda3 rims then.
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
Brokegang
Jan 3, 2016 12:45 PM
9krpmrx8
Oct 13, 2015 01:36 PM
Chapsy
Sep 22, 2015 09:57 AM
Tsurugi
Sep 7, 2015 08:27 PM
