To my own stupidity: Much harm done?
Old Aug 22, 2008 | 09:19 AM
PSTNLSS's Avatar
The Former PSNTLSS
This being my first car with a manual transmission. I ran first gear to about like 6krpm or a lil more. Then shift into 4th. I have heard a grinding, to now my knowledge realizing that, 1st to 4th is too big a jump. Any severe damage done? Only done this 4 times or so.
Hopefully the damage is minimal to the car and only to my ego
Old Aug 22, 2008 | 09:27 AM
bose's Avatar
Reginald P. Billingsly
Are you doing it on purpose? As long as you can still go into gear without grinding when you shift NORMALLY, I would suspect the damage is minimal. But I'm no transmission guru. When shifting from 1st you want to pull the shifter down and towards you, not just strait back.
Old Aug 22, 2008 | 09:30 AM
alnielsen's Avatar
Upshifting and skipping gears isn't a problem. Especially with a lower torque engine. Downshifting is a different matter.
Old Aug 22, 2008 | 09:57 AM
rotary.enthusiast's Avatar
The Local Idiot
I do a 1st to 2nd to 6th shift pattern quite often. As long as you don't try to shift really fast on the 1 to 4 shift (you're skipping gears anyway, what's the rush?) it shouldn't be a problem. If it persists I would stop trying to do it though
My guess would be that you didn't quite have the clutch fully disengaged when it happened, although I've had grinding problems on my tranny on high RPM shifts from 1st to 2nd when the pedal was on the floor, so who knows.
EDIT: Could be that your 4th gear synchros are on their way out the door and can't handle the bigger RPM drop. How old is the car?
Old Aug 22, 2008 | 10:04 AM
WantedTwo's Avatar
C4 burns real good
the synchros can only do so much work in one direction you have to let the rpm drop enough before you try to slam it in there just take your time and be kind.
Old Aug 22, 2008 | 10:37 AM
PSTNLSS's Avatar
The Former PSNTLSS
Yeah, I have an 2004.
I mean I've always known downshifting was not good to miss gears.
I was driving the car around. There's no problem getting in and out of gears.
I wasn't even thinking when I was driving those 3 times i did a first to 4th.
Old Aug 22, 2008 | 10:39 AM
dozer's Avatar
on his 3rd rx8
ur fine...i skip gears all the time when i cruise
Old Aug 22, 2008 | 11:03 AM
Aseras's Avatar
eh I dropped my car into 2nd gear at around 100mph once, the tach goes way past 10K BTW. that was at like 20K miles, and I've done another 55K since then without any problems at all.
Old Aug 22, 2008 | 11:21 AM
PSTNLSS's Avatar
The Former PSNTLSS
Yeah thanks guys. I mean its something I don't plan on doing anymore. lol. I talked to one person who made it seem like the world's gonna end. I thought to myself that transmissions should be able to take a beating. We are human we make mistakes right?
Old Aug 22, 2008 | 11:38 AM
yeah you'll be fine... that is a big jump though from 1 to 4 and i would advise against it
Old Aug 22, 2008 | 11:42 AM
you should be fine, just be careful not to down shift too quickly. No real need to skip gears though
Old Aug 22, 2008 | 04:45 PM
CyberPitz's Avatar
Huge hole is huge
If you go to fourth from first at like 9k rpms, I've noticed a good chance of grinding the gear a little bit. Just take it easy shifting down, and you'll be fine.
Old Aug 22, 2008 | 04:58 PM
Socket7's Avatar
ಠ_ಠ
Upshifting 1 to 4 should be harmless. Make sure your clutch is all the way down and don't force it. maybe take a bit of time for the revs to drop before trying to shift into fourth.
Downshifting would absolutely have to be double clutched and rev matched.
Old Aug 25, 2008 | 06:58 AM
PBlue's Avatar
Dial P for Phantom
skipping gears is fine if you rev match.
Old Aug 25, 2008 | 08:34 AM
PaPaBear's Avatar
PaPa Bear
I skip gears sometimes to keep my RPM's down and save gas. No problem here.
Old Aug 25, 2008 | 09:20 AM
Ja, you should be fine. I don't skip gears.
Old Aug 25, 2008 | 03:06 PM
NgoRX8's Avatar
grinding is a harm, but as long as it doesn't too often it's alright.
iwontevercare
Jul 18, 2015 09:25 AM
ironj221
Jul 16, 2015 10:16 PM
jalibrandi
65
Apr 27, 2005 04:11 AM
