No BEEP at redline
Old Aug 22, 2008 | 08:17 AM
Thumper3322's Avatar
No BEEP at redline
Hi...I am not getting the beep or red light when I hit the redline! Should I be concerned, happy or what? I Reved it up to about 9500rpm just to see if it would come on and nothing. Lose a lot of power around there, fuel cut off I guess.
Would it just be a fuse or something like that?
Any comments/suggestions would be appreciated!
Thx!
I also posted this in the Canadian Forum, but was hoping some of my comrades from the south could help a northern 8 brother out!
Old Aug 22, 2008 | 08:20 AM
Easy_E1's Avatar
I think your lucky. I don't know if it's a fusable item. I wouldn't think so. I believe it's integreated into the dash pod.
Old Aug 22, 2008 | 08:31 AM
I was kinda thinking the same thing, but i do like having it at the track.
huh...is there a shift light that comes on as well? Little red light on the tach? Mine's an '04 GT MT.
Old Aug 22, 2008 | 08:42 AM
Jon316G's Avatar
Grasshopper
I know that there is a diagnostic output check for the instrument cluster and one of them is for the buzzer.
To test the instrument cluster buzzer:
1) Put the key in the ignition
2) Push and hold the odometer button
3) Turn the key to the 'on' position (do not start the car)
4) Continue to hold the odometer button until 'test' appears in the lower right corner
5) Once 'test' appears, you can release the button.
6) Now push (not hold) the odometer button to scroll through various numbered options.
7) Stop when you reach output #14
8) After a full second you should hear the buzzer
9) To exit from the output diagnostic, simply turn the key to the 'off' position and back on.
Old Aug 22, 2008 | 09:03 AM
WoW thanks I will give that a go. But what if it doesn't buzz?
and are there any 8's that have a redline red dot (light) come on?
quazmosis's Avatar
Chode
^ I never knew that.
Old Aug 22, 2008 | 09:07 AM
Conundrum's Avatar
That is interesting... what else can you check with this???
Old Aug 22, 2008 | 09:21 AM
Jon316G's Avatar
Grasshopper
Simply stop at each output and wait for a second.
Here is a list of all the outputs and what they mean:
1) Buckle switch
4) Door switch
8) TNS relay
12) Speedometer
13) Tachometer
14) Buzzer
16) Fuel-level warning light
18) Ignition key illumination
22) Fuel gauge sender unit
23) Fuel gauge
25) Water temperature gauge
26) Odometer tripmeter, warning and indicator light
28) Oil pressure gauge
31) Key reminder switch
55) Dimmer switch
Old Aug 22, 2008 | 09:32 AM
Jon316G's Avatar
Grasshopper
I'm feeling generous today!
Another cool diagnostic I read about (all of these are in the shop manuals) is to test each individual speaker (just like the test tone on your surround sound system).
To perform this:
1) With the audio power on, press the 'POWER' button and simultaneously press the 'AUTO-M' button for roughly 1sec.
2) It will generate a test tone in the following order:
a) Front passenger-side door speaker and tweeter.
b) Front driver-side door speaker and tweeter.
c) Driver-side rear speaker.
d) passenger-side rear speaker.
Old Aug 22, 2008 | 09:33 AM
alnielsen's Avatar
The RX8 never came with a redline or shift light. It should be possible to fab one, however I have never had the cluster out to figure out how to do it.
Old Aug 22, 2008 | 09:35 AM
RK's Avatar
RK
It's Not Easy Being Green
No real point to those. If you need someone to get your attention everytime you need to shift you probably need more practice with a standard. Just shift when the needle gets to the red.
Old Aug 22, 2008 | 09:41 AM
Jon316G's Avatar
Grasshopper
If it doesn't work.... then we'll go from there (that's my way of creating more time to think)
I've never had the cluster apart, but I would assume that the speaker is surface mounted somewhere on/near the cluster.
But whats the chance of that going out?
Old Aug 22, 2008 | 10:29 AM
Cool...that's what I'm hearing, but for whatever reason I swear there is one on mine, just not 100%. Going to check tonight for the hole that I think is there for the light. If it's not, get the straight jacket out, cause I have lost it!! Obviously then if it is there, the person I bought it off did it. Don't really care about it, more just curious. Thx!!
fair enough!! Again it's not a huge deal, just like it for the track. Been driving standard for 12 years now and my other car didn't have one. Don't really think it's worth ripping the dash apart for a stupid little BBBuuuuZZZ noise Will let you know what I find. Thx again!
Old Aug 22, 2008 | 12:21 PM
delhi's Avatar
Grand Chancellor
1) Buckle switch
4) Door switch
8) TNS relay
12) Speedometer
13) Tachometer
14) Buzzer
23) Fuel gauge
55) Dimmer switch
Wow... this is like them video game cheat codes. Any that can instantly release another 50hp?
thanks! Someone should sticky this!
Old Aug 22, 2008 | 05:08 PM
Jon316G's Avatar
Grasshopper
I could make a DIY with various output checks.
Some of them you would need Mazda's WDS (Worldwide Diagnostic Systems) so I won't include those.
Good idea.
Old Aug 22, 2008 | 05:15 PM
MikeBusch2's Avatar
↑ ↑ ↓ ↓ ← → ← → B A
Instant 30 HP!
Old Aug 22, 2008 | 05:28 PM
quazmosis's Avatar
Chode
Did you forget the select start on the end of that?
Old Aug 22, 2008 | 05:55 PM
Originally Posted by MikeBusch2
↑ ↑ ↓ ↓ ← → ← → B A
Instant 30 HP!
Old Aug 22, 2008 | 05:58 PM
1) Buckle switch
4) Door switch
8) TNS relay
12) Speedometer
13) Tachometer
14) Buzzer
23) Fuel gauge
55) Dimmer switch
That's pretty sweet...worked and got the buzzer noise. Redlined it and it went off So I don't know if this fixed it, or I was smokin some crazy shat last night but all is good. Oh and I have no red dot light either. I was really out of it last night/this morning
Any way to modify these?
Thx again!!
Old Aug 22, 2008 | 11:00 PM
greg985's Avatar
The 337
I did that, and a bunch of things said they were off. I didnt know what they were so I just left them alone
Old Jun 30, 2009 | 09:24 AM
Youwonder's Avatar
5 Boro Rotary......5BR
Jon316g Was that on the owner manual???? Mine don't beep when I redline it... People like the beep some don't... But I haven't herd the beep since I had the car.... And i wanna hear it I'm going to try the output check thanks jon316g.....
Old Jun 30, 2009 | 01:52 PM
04RX8man's Avatar
Rotary Powered Countryboy
revival?
Old Jun 30, 2009 | 02:13 PM
Jon316G's Avatar
Grasshopper
The diagnostic menu I posted above is from the Shop Manual, not the Owner's Manual.
Old Jun 30, 2009 | 02:17 PM
Jon: thanks for the useful info in here!
I might have to try out the speaker test.
Old Jun 30, 2009 | 06:48 PM
Youwonder's Avatar
When u go to #14 for buzzer I hear it and the indash say on. I hear the buzzer too So I turn it to off to lock?? Or just ACC were the radio stays on and the indash turns off??.... Cause I turned it off for like 5 seconds on lock mode and I revved and nothing even when I was driving...it says reset when I hold the two dash buttons?? Do I reset??? I Really want the beep...
