Need some help please odd things happening
Old Aug 21, 2008 | 12:04 PM
Spazzychaz's Avatar
Spazzychaz
I drove to work with no problems at all today, parked my car in parking lot and later in the day decided to go to lunch. I came got my car drove to lunch and then parked it. I came out after lunch to my car I got in and the traction control light was solid like I had a dead battery also my mileage was reset. My radio stations and clock were not reset though.
I pull over restart the car and the traction control light goes off. i continue to drive and about 1 mile down the road pull to a light. I am sitting at the light waiting it to turn green. All of a sudden all my electronics turn off and all the needles spike real quick and go back down. My key is in the ignition in the on position. I try to start the car again and it does not turn over at all. the electronics all come back on and I try to start it again starts right over and traction control light is on again. I drove a few miles back to the office and in the parking lot did a quick check for blown fuses or anything liek that. I couldn't find anything.
I am just worried I am going to be travelign down the highway sometime and this will happen at higher speeds. Anyone have any ideas of what this could be or any rememdies on how to fix it. Thanks for the insight and hopefulyl I can figure something out
Oh, by the way. I do have a Tein EDFC unit that has been installed since around May and I haven't had any problems at all with that and none of the fuses are broken there.
Thanks again.
Old Aug 21, 2008 | 12:05 PM
dead battery, or your terminals are not secured.
Old Aug 21, 2008 | 12:38 PM
check your battery terminal connections
Old Aug 21, 2008 | 12:51 PM
dozer's Avatar
on his 3rd rx8
check your tire pressure...
Old Aug 21, 2008 | 01:56 PM
CyberPitz's Avatar
Huge hole is huge
Break Fluid?
Old Aug 21, 2008 | 02:23 PM
dozer's Avatar
on his 3rd rx8
no crack left?
Old Aug 21, 2008 | 02:28 PM
nmarz77's Avatar
The magnetic poles are shifting.
Old Aug 21, 2008 | 02:53 PM
Deathcraft's Avatar
It's the end of the world as you know it! take cover!
Old Aug 21, 2008 | 04:46 PM
Spazzychaz's Avatar
Spazzychaz
Well, thanks for some help. I came home and had no problems gettign home. Now I did leave the car running in neutral and took the positive battery terminal off and it continued to run. Any other ideas?
Old Aug 21, 2008 | 05:30 PM
Old Rotor's Avatar
WHAT!!!
Old Aug 21, 2008 | 06:26 PM
CyberPitz's Avatar
Huge hole is huge
Did you just say you left your car running and disconnected the battery?!?!?!?!?!?!?!?!?!jarjgoiaerjgfaewmgviaemrg oieg
*World explodes*
Old Aug 21, 2008 | 06:47 PM
Deathcraft's Avatar
I'm telling you it's the end of the world. The earth spins 0.00000000000000000006 mph slower and it effects the way people think.
Old Aug 21, 2008 | 07:49 PM
Spazzychaz's Avatar
Spazzychaz
So, did I do something I wasn't supposed to? I am lost I am just asking for help is all.
Old Aug 21, 2008 | 08:06 PM
StealthTL's Avatar
Metatron
When you take the battery out of operation, the car is running on the (18+volts) the alternator's output - very bad for the electronics.
Sounds like one or both of your terminals were loose, if the steering motor gets a bad connection, it will lock up and the traction light will be on.
Fix your terminals, or buy a new battery.
If the car still runs, you are lucky......
S
Old Aug 21, 2008 | 10:04 PM
Spazzychaz's Avatar
Spazzychaz
Thank you for the information, looks like vehicle runs fine. Hopefully as it was just a quick off terminal on terminal thing there won't be any other damage. Thanks again for the help.
Old Aug 21, 2008 | 11:03 PM
duck and cover!
Old Aug 21, 2008 | 11:24 PM
Rx8urZ's Avatar
floor mats???
Old Aug 22, 2008 | 02:46 AM
Speyrod's Avatar
Batman mask on the CHMSL??
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
ed0128
Sep 9, 2015 04:50 PM
mattymack
Sep 6, 2015 10:33 PM
rxwilly8
Sep 2, 2015 02:42 PM
