Spark Pulgs Fo N/a
Old Aug 18, 2008 | 02:43 PM
G3RX8's Avatar
Spark Pulgs Fo N/a
I was wondering if we change the heat ranges colder for FI cars would it do anything to make the spark plugs hotter for N/A cars. Just a thought
Old Aug 18, 2008 | 03:20 PM
huh>?
Old Aug 18, 2008 | 03:34 PM
ken-x8's Avatar
Nope. Maybe generate some preignition under hard running.
Old Aug 18, 2008 | 04:56 PM
quazmosis's Avatar
Chode
Wouldnt that create detonation?
Old Aug 19, 2008 | 09:49 AM
G3RX8's Avatar
idk what would happen. FI rx8 put colder spark plugs in so they dont get detonation. i was wondering what would happen if i put hoter plugs in instead of the trailing plug being so cold make it hotter. this may make the car run a little leaner and make a couple horses just an idea have not tryed looking for answers from someone smarter then me which there are plenty of them
Old Aug 19, 2008 | 10:40 AM
quazmosis's Avatar
Chode
^ I dont know if you want to make the car run any leaner than it already is. I wouldnt mess with different plugs but thats just me.
I think there are better and safer alternatives to pick up a couple more horses you speak of.
Old Aug 19, 2008 | 03:30 PM
G3RX8's Avatar
i always thought with factory tune our cars ran alittle rich
Old Aug 20, 2008 | 09:44 AM
G3RX8's Avatar
thats what i wanted to know i was wonderind if a hotter plug would burn more fuel
Old Aug 20, 2008 | 10:41 AM
quazmosis's Avatar
Chode
opps I meant richer not leaner.
Old Aug 20, 2008 | 03:04 PM
G3RX8's Avatar
so then what do they do for FI cars. b/c i have no idea
Old Aug 20, 2008 | 06:15 PM
kersh4w's Avatar
Hit & Run Magnet
they use colder plugs
Old Aug 20, 2008 | 10:23 PM
Nubo's Avatar
Lubricious
The only reason for hotter plug would be if your plugs are fouling after low miles. Even then, the reason for fouling needs to be understood first and resolved if possible. In some cases, hotter plug could be the answer -- cold environment, short trips, gentle driver. As mentioned, hotter plugs were used for awhile early in the car's run when they were running extremely rich. Nowadays I doubt if very many RX-8 would benefit from hotter plugs.
Hotter plugs increase the risk of detonation.
Conversely, colder plugs decrease the risk of detonation, and that's why you are seeing them used in FI application.
In normal service, colder plugs will foul too quickly.
So, there is a balance between detonation on one hand and fouling on the other. The standard heat range is the best compromise for most drivers.
Old Aug 20, 2008 | 10:31 PM
rx8 man's Avatar
plugs
Running "rich" and spark plug heat ranges are different issues. Mazda did supply RE6s in some climates during a period so as to prevent fouling.
RE6s are what my Rx8 come with, but I've just put NGK BUR7EQ s(rx7 plugs) in to the leading, haven't had them in long, so don't know about flooding...Yet.
Old Aug 21, 2008 | 02:32 AM
Jon316G's Avatar
Grasshopper
Detonation is caused by an instantaneous ignition of the remaining fuel/air mixture ahead of the advancing flame-front in the form of an explosion rather than controlled combustion. This is due to the unburned mixture being heated and pressurized by the advancing flame front to the point where it spontaneously ignites.
Pre-ignition is a different phenomenon to detonation and occurs when the fuel/air mix ignites BEFORE the spark plug fires due to hot spots in the combustion chamber acting as an ignition source.
Shankapotamus3
Mar 14, 2021 03:53 PM
tjohnmeyer
Sep 28, 2017 05:03 PM
Oct 3, 2015 09:51 AM
Danield97
Sep 30, 2015 05:59 PM
Jb4ker96
Sep 27, 2015 10:06 PM
