help with exhaust install...
Old Aug 12, 2008 | 11:25 PM
terreezzy's Avatar
how would u take these nuts out.... circled in red
its like bolt on hella tight
Old Aug 12, 2008 | 11:33 PM
NgoRX8's Avatar
you just unscrew it. spray it down with WD-40 and start torquing. it's on pretty tight from factory and the spring makes it tighter. if its rusted hold the head of the bolt, sometimes that side will come out instead. use a impact gun or a long extension.
Old Aug 13, 2008 | 01:05 AM
snowflakes's Avatar
.DriVeN.
Use some Liquid wrench or wd40 works too , but i would use something a bit more concentrated, and hit around a bit with a mallet[rubber] for a break off and then use an impact gun to take off. if no impact gun, just have some man power and break it loose, but Do not Strip it.~ DO NOT use an extention Too Long, you will strip the bolt or even break it off.
Old Aug 13, 2008 | 01:21 AM
lilring's Avatar
Finally a MT
just take one hell of a breaker bar of some sort and do it that way... it wont be easy but just keep at it and it will work.
Old Aug 13, 2008 | 01:25 AM
tug your skirt down and make sure you know how to remove a bolt..
no lube required..
Old Aug 13, 2008 | 01:37 AM
NgoRX8's Avatar
no lube required..
you torque it, break it, replace it.
Old Aug 13, 2008 | 01:41 AM
they are the two bolts behind the springs.. i am not going to say you could take them off with you fingers! but if they are not hot. well, they are simple..
not like trying to unbolt the cat. with the nuts that will not turn.
Old Aug 13, 2008 | 01:49 AM
NgoRX8's Avatar
yup, the bolt are attached to the cat side and sometimes they do off that way. happened to me, just gotta get at it hard enough.
haha... the cat... so true...
Old Aug 13, 2008 | 02:23 PM
quazmosis's Avatar
Chode
^ hahahhahaha
Old Aug 13, 2008 | 02:45 PM
SilverHokie's Avatar
I'm Delaware Fast
^^ best post today. ahahaha.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
arexatemate
Oct 28, 2019 08:16 AM
mdl0209
May 23, 2019 05:46 PM
Jb4ker96
Sep 27, 2015 10:06 PM
