Real time Aero adjusting wing.
Old Aug 11, 2008 | 04:41 PM
Rotr8's Avatar
whines all the way home
A neat innovation for all you AutoX and track stars, AeroMotions is developing a wing that is computer controlled to adjust and adapt to your aero needs,,,,
Pretty neat stuff if it proves out...
http://www.autoblog.com/2008/08/11/d...poiler-debuts/
Old Aug 11, 2008 | 06:03 PM
dynamho's Avatar
I doubt applicability to auto-x. Most auto-x is done in 2nd gear - not fast enough to significantly benefit from aero downforce.
Old Aug 11, 2008 | 06:19 PM
superglue's Avatar
n00b post whore
I'm with you. You're not going fast enough around turns for it to do much in autox..... but out on the track, that could prove to be very useful.
alfy28's Avatar
^^ agree. i can see thsi helping track drivers. but as for auto x i dont see the purpose of it. but great find OP
Old Aug 11, 2008 | 06:37 PM
GlenAnderson's Avatar
Lurker
Actually, I was talking with one of the developers about this yesterday (the prototype car is a local auto-x car) and the wing has such an aggressive profile that it starts generating downforce at around 30 mph.
They have done a lot of research and testing on this...it is pretty trick stuff.
Old Aug 11, 2008 | 07:17 PM
BlueEyes's Avatar
been done (in the 70's no less) and banned in real racing. I don't know about parking lots. You can generate plenty of downforce at lowspeeds.
Old Aug 11, 2008 | 07:33 PM
TopGear8's Avatar
mkuhnracing.com
Wow that thing is ugly!
Old Aug 11, 2008 | 10:00 PM
superglue's Avatar
n00b post whore
At 30mph downforce sounds like overkill. Especially if you're not getting any downforce on the front.
Old Aug 11, 2008 | 10:52 PM
dynamho's Avatar
I'm with superglue.
I'm still skeptical about practical application at low speeds.
Yet, the split wing design is really interesting... like aero "stabilizer bars".
Anyone know if research is being done on lateral dynamic ballasts that move around the car to offset cornering g's? I know, pretty crazy idea.
Old Aug 12, 2008 | 11:23 PM
altiain's Avatar
Sparky!
Wrong. Check most of the top X Prepared or Street Modified 2 cars, and you'll find that a lot of the top cars use big wings... and generate meaningful downforce at "parking lot" speeds.
Better yet, check out the aero aids on A Modified, B Modified, or Formula SAE cars. As a former contributor to the University of Texas at Arlington's Formula SAE team, I can tell you that the aero on our cars was developed using hundreds of hours of computer simulation and wind tunnel testing, and it worked.
Old Aug 13, 2008 | 12:45 AM
superglue's Avatar
n00b post whore
I'm not doubting that it makes downforce, I'm just not seeing how useful actual downforce is at autox speeds. Maybe for a super light that showed up on a trailer.
Old Aug 13, 2008 | 10:08 AM
dynamho's Avatar
OK. Any applicability to stock or mildly modified classes, like street touring? It'd have to be quite an large wing to generate proportionally significant aero downforce. Any wing of that size in the aforementioned classes likely would be more of a drag/weight hindrance than help.
Old Aug 13, 2008 | 10:18 AM
alnielsen's Avatar
There is a local guy, with a miata, that is working up a system to tilt his wing more vertical when he hits his brakes. This would work more like the Chaparral 2G. He is using air pressure as the actuator.
http://uk.youtube.com/watch?v=qrQjkaMzpZA
Old Aug 13, 2008 | 03:31 PM
dynamho's Avatar
That's cool.
Old Aug 14, 2008 | 02:05 PM
Rotr8's Avatar
thats pretty wild, I wonder how much the air hydrolics weigh,, looks like a very nimble responsive system...
Old Aug 15, 2008 | 03:10 PM
Wolverine's Avatar
X-Men
Looks like the new attack KITT will have something similar. LOL.
http://www.youtube.com/watch?v=opYYw...eature=related
Old Aug 16, 2008 | 01:09 AM
superglue's Avatar
n00b post whore
What are air hydrolics?
I think you mean "pneumatics" and for future reference, it's spelled "hydraulics".
He's using a very simple circuit with nothing more than some tubing, a valve, an air reservoir, two cylinders, and a limit switch under the brake pedal. You can get a set up like that for less than $100 if you go with the cheap stuff. Only thing that would add significant weight would be the air reservoir which could be anywhere from 10~20lbs fully pressurized.
Seems like it would have minimal gains. And since it's definitely not legal in stock class, then he would be better off with proper brake upgrades and better tires.
That's my $0.02
Old Aug 16, 2008 | 07:50 PM
I'd like to see that Sero motion.
And the guy in the Miata is gonna stop alot faster.
Dokuji
Nov 1, 2016 02:51 PM
uZu
Dec 30, 2015 12:35 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
DVerdeyen
Aug 31, 2015 10:41 PM
Jazzmeson
Jul 21, 2015 02:54 PM
