Fuel Additive help. What to use and what not to use?
Old Aug 11, 2008 | 10:03 AM
DSM_Outlaw's Avatar
I useually use additives in my other vehicles and was wondering if its ok to use these on the rotary engine. What do the other members on this site use and does it help them out? Marvel Mystery Oil? Engine Restore? B12 is the other one i use i think.
Old Aug 11, 2008 | 10:08 AM
A Simple Search saves you a lot more time than sit and wait for replies.
Old Aug 11, 2008 | 10:13 AM
ken-x8's Avatar
Don't use any additives. Just buy name brand gas, and don't fill up if there's a tanker at the gas station. That goes for all your vehicles.
Someone will probably respond with premix. That's a different deal than additives.
Ken
Old Aug 11, 2008 | 12:32 PM
Jax_RX8's Avatar
Got Another Rotary
Summary here:
https://www.rx8club.com/showpost.php...&postcount=968
More good data here on Premix/additves:
https://www.rx8club.com/series-i-tech-garage-22/gas-oil-premix-thread-99636/page20/
Old Aug 12, 2008 | 11:36 AM
DSM_Outlaw's Avatar
i know that premix does absolutly nothing according to my local mazda and rotary tech at the dealer ship and i already had to replace the whole exhaust and engine and i think it was done over buy the premix
Old Aug 12, 2008 | 11:43 AM
DSM_Outlaw's Avatar
Ken
yeah i knew about that, Dont fill up either during the middle of the hot day because a portion of the fuel evaps and it turns into fumes. Dont squeeze the trigger all the way because all your gonna do is get some of the fumes to to mess up the computer reading how much fuel your getting making it read more. I always pull the trigger to one or maybe two clicks when you put it on automatic.
Old Aug 12, 2008 | 12:24 PM
SpIcEz's Avatar
Make more sense and less noise please!
Old Aug 12, 2008 | 01:17 PM
cornholio135's Avatar
SARX
I use BG44K about once every 2 months... works great to remove carbon buildup
DO NOT EVERY USE OCTANE BOOSTER. I HAD IT FOUL A SET OFF PLUGS!!!
Attached Thumbnails Fuel Additive help. What to use and what not to use?-bg44k.jpg
Old Aug 12, 2008 | 11:38 PM
wow,
lots of bad info here.
i would say that b&g 44k every 10k miles is a great idea. and run the **** out of it on that tank.
and if you think premix might be good for you.
i would read anything jax rx8 has posted, and make a choice. it would be win, win.
Old Aug 12, 2008 | 11:40 PM
wow,
did you get that from a friend on the internet???
fail.
Old Aug 13, 2008 | 05:31 AM
DSM_Outlaw's Avatar
Originally Posted by swoope
wow,
fail.
If u leave a gas can in the sun for a lil bit what happens???? It expands right?What happens if you pull the vent cap?
Old Aug 13, 2008 | 07:51 AM
r0tor's Avatar
my personal opinion (and the usual case accordingin to rebuilders) is carbon will kill your engine far before lack of lubrication... so i use Lube Control FP+
Old Aug 13, 2008 | 12:18 PM
Nubo's Avatar
Lubricious
Some fumes come out. But that doesn't mean you need to be careful with your "clicks" when you fill your tank. You don't have an airtight seal between the nozzle and your filler tube. There are always fumes in the tank unless it is 100% full. The fumes get pushed out as you fill. It doesn't matter how *fast* they get pushed out (within reasonable limits built into the pump). The fumes escape through the filler tube, and they either enter the atmosphere, or in more reasonable places like California, they are recaptured by a device that fits over the nozzle. Fumes that accumulate once the cap is tightened are handled by the evaporative control system of the car.
There are 2 things to understand about fueling when it's hot, and maybe this is where you get confused.
1, the cooler gas from the underground tank can expand a bit once it sits in your tank on a hot day. So if you fill up, take a VERY short drive, and park, then there is a potential for liquid gasoline (instead of fumes) to get into the evaporative control system and cause problems. This is probably only an issue if you deliberately overfill your tank.
2, unless the pump has a temperature correction built-in, the measurement can be off and you can get slightly less gasoline than if you had filled up when it was cool.
Old Aug 13, 2008 | 12:35 PM
Socket7's Avatar
ಠ_ಠ
Consumer reports debunked this just the other day.
Gasoline is stored in underground storage tanks. The gasoline inside them is kept at a static temperature by the earth. What little is in the hose could heat up, but the amount that would be heated is insignificant.
Old Aug 13, 2008 | 12:43 PM
alnielsen's Avatar
Nubo
Today, all areas of the US recapture gas fumes as a car is being fueled.
When filling your tank, you aren't suppose to fill completely to the top of the filler neck. You are only to fill until the nossil clicks off. This leaves room for expansion and keeps the charcoal filter, in the evap system from being polluted.
Old Aug 13, 2008 | 05:14 PM
Nubo's Avatar
Lubricious
Originally Posted by alnielsen
Nubo
Is that right? I went to Vegas in June and could swear I encountered pumps without the recapture equipment. Maybe they were grandfathered?
I think we agree about not deliberately overfilling.
Old Aug 13, 2008 | 05:22 PM
Nubo's Avatar
Lubricious
I agree and have made that same argument before on this very forum.
https://www.rx8club.com/showthread.p...re#post1397005
The difference would be tiny, agreed. But not zero, which is why I used the word "slightly". And there are places where the pumps are required to be temperature compensating, by law.
Old Aug 14, 2008 | 02:52 AM
sorry,
the car is not a gas can in the sun.. it is in the shade.
get back to me on this.
Old Aug 14, 2008 | 06:08 PM
DSM_Outlaw's Avatar
nope but the gas stations aint all hidden under trees either. I never been to florida but im pretty sure its like the concrete jungle over there and not like a amazon
Old Aug 14, 2008 | 06:10 PM
DSM_Outlaw's Avatar
here is a lil info on saving at the pump to help clear things up. I just search and i found some info. notice number four on there.
http://www.squidoo.com/saveatthepump
Old Aug 14, 2008 | 06:15 PM
DSM_Outlaw's Avatar
www.gasbuddy.com is alot of help too. It covers the U.S. and Canada as well
Old Aug 14, 2008 | 06:42 PM
DSM_Outlaw's Avatar
http://www.youtube.com/watch?v=8MlF1...eature=related
Number six: Cooler Temps Means Less Vapors
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
ShellDude
Oct 1, 2015 09:55 PM
RotaryMachineRx
Sep 29, 2015 10:26 PM
DeltaJ802
Sep 29, 2015 01:20 PM
