View Full Version : My car died while on vacation in the USA :(
Paudio 08-08-2008, 09:54 PM HI Everyone
my Car died today in the middle of nowhere on my way home from Florida going back to Ontario. Was Driving around 130KM for 5 hours or so. Then our of no where the car turns off. I pull off to the side of the highway. I tried to turn it back on it turned on and was running super rough and sounded terrible.. after 3-4 seconds it shut off again. I was able to start it one more time just to get it off the road a little better so I felt safe to exit my car. Then it would not start anymore. Not the Battery all electrical was fine. The Check engine light came on and flashed 3 times just before it died. and that was it.
Any idea what could have gone wrong?
Of Course the dealership in this small town is closed tomorrow but they said the would look at it first thing monday morning.
So now I am stuck paying 100 a night till at least monday assuming they can fix whatever is wrong on monday.
Car is a 2005 with 75XXX KM. is the motor still covered by any warranties?
Paudio 08-08-2008, 10:03 PM Also
Don't if anyone has ever tried to call the roadside assistance while in the USA. But it Doesn't work for call from the USA. The paper I had said call from Canada and the USA.
I called my Dealership and they gave the USA roadside assistance number to call. I called them and they said to cll the 1-877 number..lol I explained that it wasn't working. They were really good and got me a toe truck within 15 mins and they had to toe my car 47Miles to the nearest Mazda dealership and COVERED the whole trip even though my car had 75XXX KM and is over 3 years old. So I was out of the Roadside assistance warranty.
I was happy...:)
http://img.photobucket.com/albums/v210/paudio/photo3.jpg
Daemos 08-08-2008, 11:33 PM Questions to you are:
Do you premix?
have you ever removed the cat?
Auto or Manual?
do you redline once a day?
driving habits?
used any oil heavier than 5w-20?
PS warranty for the rotary core has been extended to 8 years 160k km
TurboEight 08-08-2008, 11:36 PM Ok, I'll bite..
check the CATS......I am also certain your cats are clogged.
1. High KMs..
2. you said your CEL flashed a couple of times...(that states cat failure, I believe)
3. Your car's drivtrain warretny should be still good..
but i don't know if that covers the cat. check with your warranty book.
Paudio 08-08-2008, 11:54 PM Questions to you are:
Do you premix?
Auto or Manual?
driving habits?
Thanks for the comment
Premix? I don't know what your talking about
Manual
I haven't hit the redline in 6 months give or take a month
Driving habits - No city driving .. Just regular driving I don't kill it.
All my oil changes since new I have done at the dealership.
Paudio 08-09-2008, 12:02 AM Ok, I'll bite..
1. High KMs..
I was diving and noticed the pick-up wasn't as responsive just before it happened , then the Check engine light flashed 2-3 times back to back and 3-4 seconds later the car shut off.
Now that you say Cat.. thinking back when I did re-start it . the mufflers sounded so loud that I though they fell off and the first thing i did when i got out of my car was look and see if my muffler fell off.lol..
Any chance it damaged the motor? If it was just a clogged CAT? Anything I should be asking the dealer if they say that to make sure they didn't miss anything?
Thanks Alot
Thanks for the comments!
laythor 08-09-2008, 12:24 AM Sounds like a clogged cat. Have the dealer check it.. refer them to tsb 01-014-08
http://www.finishlineperformance.com/pdf/rx8/bulletin/01-014-08-1924f.pdf
TurboEight 08-09-2008, 12:49 AM Thanks for the comment
Thanks Alot
Yep, I was almost certain you had a clogged cat.
just take it to the dealer and say WTF.....my car died in middle of my damn trip..
see what they say....
check if they have any recalls done on the car.
from your driving habbits and info you are giving us, its pretty much sounds like a dead cat.
If dealer is willing to help you out..nothing come out of your pocket
if they want to be dicks...
its like ~1400 for a OEM cat...but that I 'm not sure of.
GL
SpIcEz 08-09-2008, 12:51 AM 75000km isnt high mileage it = 46k miles
Daemos 08-09-2008, 01:10 AM Thanks for the comment
Manual
Premixing is adding addicitves to the gasoline to help clean out carbon deposits and lubricate the apex seals of the engine.
Manual is good
Rotary engines love to be driven hard...saying goes redline once a day keeps the carbon away.
Oil changes...are good but did you ever try to do some extra maintenance? I change the oil every 4000km or so, and top it off when needed.
Unfortunately the rotary engine isn't as easy to maintain as a piston engine and it involves a little extra TLC.
But if the cat is clogged then the dealership should replace it as well.
Ka Kui 08-09-2008, 01:18 PM Oh man, keep us update on what the dealer says.........
Mazurfer 08-09-2008, 01:28 PM Check the coils as well as the cat.
nate340 08-09-2008, 10:03 PM when i took my 8 to florida and back the only issue i had was the secondary ports were sticking. i had to make sure i redlined it every once in a while to prevent it from happening
Paudio 08-11-2008, 09:31 AM Dealer called me this morning and said its my coils that need to be replaced. And Since I am past my 36/80000 warranty I have to pay.
They said the Cat looks fine
The dealer said it will be 1200 and change to do everything
Dose this sound right? Coils are not covered on any other engine warranty? I did look in the book but I could not find anything for coils so I am assuming I am out of luck.
And I am stuck for another day! yay...
They said they were going to overnight the parts so I could be out of here tomorrow.
Paudio 08-11-2008, 09:36 AM Premixing is adding addicitves to the gasoline to help clean out carbon deposits and lubricate the apex seals of the engine.
Manual is good
No I have never done any pre mixing -- I use Shell V-power.lol they claim to clean the engine..I guess not
I will make sure to redline line now at least once everytime I take the car out.
I change my oil every 5000KM the dealership tells me every 8000km, but that seems to long. I check and top up the oil as needed. I usually check the oil every 3 fill ups to see where it is at.
The dealership said the coils need to be replaced. that make sense?
TurboEight 08-11-2008, 10:37 AM makes a little sense...
dont get them done at the dealer, you can opt for the BHR coil upgrade I believe they are around ~500, and the fair much better then the crappy OEM coils...our coils are known to fail....
EDIT: Tell to check our cat as well....
Paudio 08-11-2008, 11:15 AM makes a little sense...
Thanks for the advice, I am going to get them done here since i am in the middle of nowhere and I want to get out of here since I have been stuck here for 4 days already paying 100 a night at the hotel. :( They said they will have the car ready first thing in the morning.
I asked them to check the cat and they said its fine..I don't know if they actually checked it our not.
Smokin_LaLa 08-11-2008, 03:23 PM sorry to hear about your dilemma bud. My 8 just died this morning :( I am pretty sure it is flooded though as I didnt drive it from last Fri...My sister's fiancee went to move my car into the garage and did not rev it before shutting it down. Gonna use the deflood procedure, hope it works man
Thief 08-11-2008, 05:17 PM sorry to hear about your dilemma bud. My 8 just died this morning :( I am pretty sure it is flooded though as I didnt drive it from last Fri...My sister's fiancee went to move my car into the garage and did not rev it before shutting it down. Gonna use the deflood procedure, hope it works man
Kill him!!!!
Paudio 08-11-2008, 10:13 PM Well I got my car back today
Runs great feels great!
and I and 1200 less bucks in the banks!
Tomorrow I hit the road to come back home!
Ka Kui 08-11-2008, 10:55 PM Finally everything is done eh.......... drive safe!!!
Paudio 08-11-2008, 11:04 PM Finally everything is done eh.......... drive safe!!!
Where in Richmond Hill you from?
I am at Bathurst and Regent Street
Ka Kui 08-12-2008, 07:04 AM Thanks for the comment
I am at Yonge and 19th.........
Paudio 08-12-2008, 12:32 PM MY car is down again :(
I lasted about 3 hours....
now I am at ellis Mazda...
They just took my car in so hopefully its going to be back on the road soon....
I am never going to get home
Stuck in Georgia for life
Rotary Mike 08-12-2008, 12:41 PM MY car is down again :(
Dude, that is bad news. I feel for you. Stories like this get me a bit nervous about getting my car
Paudio 08-12-2008, 01:57 PM Dude, that is bad news. I feel for you. Stories like this get me a bit nervous about getting my car
At least this dealership has wireless internet ..lol
They said I should be back on the road for 4:30
The check engine light was throwing a code for the #2 wire?
So they are replacing all my wires again. (just changed yesterday)
And do an engine clean to clean out any carbon I might have inside.
They said it "should" get me home then I need to get my motor checked to see if they need to replace it.
Did they give you a rental car for 22 days in the shop for yours?
Rotary Mike 08-12-2008, 02:02 PM At least this dealership has wireless internet ..lol
Since I am technically not the owner, no.
Luckily I have a girlfriend and parents who have cars I can borrow. I am going to try get it back tonight
Smokin_LaLa 08-12-2008, 04:01 PM sorry to hear about your troubles dude......On the plus side i actually did not have to de flood my car last night, all i did was charge up the battery with a battery charger, seems like i need a new battery
shaunv74 08-12-2008, 04:09 PM MY car is down again :(
Sorry to hear about your troubles. I would definitely ask for my money back from the original dealer since they didn't fix your problem. $1200 is an outrageous amount. Coils are $30 eachx4 and it should take them 1 to 2 hours max to install. Should have been no more than $350-$400 to install new coils.
Also it could still be the cat. Tell them to physically unbolt the cat. and look inside. It can be bad and still not have a CEL going off. The cat. should be covered under warranty if it needs to be replaced since it has a longer warranty.
If you need to price compare any parts, check warranty periods, or recalls/TSBs check out this Mazda Dealer website: http://www.finishlineperformance.com/store/home.php
They have a ton of info. on parts and TSBs for the RX8.
Let us know what they say next.
Paudio 08-12-2008, 10:51 PM Sorry to hear about your troubles. I would definitely ask for my money back from the original dealer since they didn't fix your problem. $1200 is an outrageous amount. Coils are $30 eachx4 and it should take them 1 to 2 hours max to install. Should have been no more than $350-$400 to install new coils.
Sorry I should have been more clear on what else I had done.
I also got new spark plugs and new wires I think that was 200 and change
Then I got a throttle body and erg vales cleaning and new air filter. It was time to do it so I just did it
And I did an engine cleaning service. I think called de-cardonation that needed to be done thats what made it all add up.
Your correct about the coils total service for them was 412.XX with taxes
Today what happen was the code going off was wire 2 miss-fire
The looks like no fault from the other dealer was actaully just a bad wire from the factory. The dealer today replaced all the wires (for free of course). Then they took it for a 22 miles test drive.
The tec said it still feels like its missing some power but I should beable to get home and get my dealer to preform the TSB for the cat and motor compressions etc. I didn't want them to do it cause I just want to get home.lol Hotels are getting expensive. He printed all the papers and said to give it to the service guys at my dealer at my house.
But I just drove 8 hours right after on the HWY and had no problems. I am 8 hours from home. Hopefully I make it!!!
Ka Kui 08-12-2008, 11:09 PM Drive safe..............
shaunv74 08-13-2008, 12:14 AM Glad to hear it's running better for you. Definitely have the cat. PHYSICALLY inspected to see if it's melted when you get home.
Drive safe...
