How often does your A/C cycle?
Old Aug 7, 2008 | 01:46 PM
Vasichko's Avatar
Im just wondering how often your A/C cycles?
I dont know if I should have mine looked at because I can hear the clutch cycle every 20 seconds or so.
Old Aug 7, 2008 | 01:59 PM
Old Rotor's Avatar
Thats normal...
Old Aug 7, 2008 | 02:05 PM
Cuz Mazda gave us an underpowered A/C system. if they dont engage it every 20 seconds or so. We might ask for a refund of our cars.
On hot days, mine cycle like every 10 seconds or less.
Old Aug 7, 2008 | 02:12 PM
luis@championsmotorsports's Avatar
possible problem
an ac system that cycles often may have improper or low levels of freon...it should cycle based on the ambient temp sensor on your evaporator under the dash and according to your pressure cycling switch...this is a universal relation... not sure how the older ac system should work...
Old Aug 7, 2008 | 02:14 PM
possible problem
get a free ac check...they may tell you different...
Old Aug 7, 2008 | 02:34 PM
04RX8man's Avatar
Rotary Powered Countryboy
mine also does it.....not sure if it's right or not but does do it..
Old Aug 7, 2008 | 10:14 PM
It has been reported that several members were low on freon from the factory.
Old Aug 7, 2008 | 10:22 PM
Yum.
Gonna go have it check tomorrow then. hoho ~
Old Aug 7, 2008 | 10:27 PM
04RX8man's Avatar
yeah i should....oh(not to steal a thread) but is there a certain time/mileage you should recharge ur a/c? i'm at 35,xxx and its never been done
Old Aug 7, 2008 | 11:19 PM
gregs's Avatar
Pull My Finger
most of the mazdas do not come with their system full of freon
Old Aug 7, 2008 | 11:59 PM
Vasichko's Avatar
How hard would this be to refill myself?
Aside from purchasing a can of R134a what else would be needed?
Old Aug 8, 2008 | 12:04 AM
You can do it, but don't tell the enviromentalist. Your suppose to save the gas and get it recycled.
Old Aug 8, 2008 | 12:13 AM
Conundrum's Avatar
You don't need to recycle if you are recharging. Just adding more gas to the system, but you do need to know what PSI to charge the system to.
Old Aug 8, 2008 | 12:14 AM
Im wondering too. I see all these R134a "ICE COLD" Can thinggy @ Autozone. I always wonder should I check mine.
Maybe I should look at the spec and google to see how to add Freon myself "Safety"
Old Aug 8, 2008 | 02:29 AM
if you have a 04 or 05 please read and try this.
i had to go way back to get it. enjoy.. it has to be done everytime you reset the ecu. so you might print it out and put it in the glove box..
and yes it does make a difference..
https://www.rx8club.com/showpost.php...54&postcount=8
RevMeHarder
Jun 1, 2026 02:30 PM
nadodave
Aug 28, 2019 05:55 AM
OnebaddRx8
Aug 25, 2019 11:34 PM
Digitz0070
55
Jul 25, 2017 08:40 PM
stickmantijuana
10
Sep 13, 2015 11:28 PM
