Batt Light plus doesn't rev up
Old Aug 5, 2008 | 07:07 PM
Komanji's Avatar
I searched but haven't found this same thing.
Heres the deal just had 2nd gear fixed for the 2nd time. And they fix power steering, which still seems to turn left easier than right but whatever...Also changed my positive terminal for some reason not sure yet why.......Anyhow
Batt light came on. So i changed the batt, and had my alt rebuild cause the regulator was bad. Now im getting a batt light still and the car doesnt seem to wanna move to fast (like its in limp mod or something). Any advice? please help. I have a good amount of wrench time im just not good at electrica crap like this. I would rather change a motor out than spend all day trouble shooting
Old Aug 5, 2008 | 07:33 PM
Nubo's Avatar
Lubricious
Check the battery connections. Make sure the posts are clean and bright, the clamps are snug, and also double-check that all the connections to the positive clamp are well-joined and corrosion-free, and make sure the wrench-monkeys didn't leave a wire hanging somewhere when they changed the positive terminal. And WHY did they do it? That could be an important clue.
As far as power steering harder in one direction -- search the tech area for threads about the power steering wiring conectors -- the originals have problem that can cause car to turn harder in one direction.
Old Aug 5, 2008 | 08:22 PM
Outkast187's Avatar
Without proper voltage, car wont rev up...it wont have the juice to throw to the coils. On a side note.. I had a corvette that did this exact thing. Voltage regulator in alternator went out, sent 25v to the ECM, killed the ECM. It ran, but in limp mode most of the time. Changed ECM, chip(sometimes kills the chip, which will destroy new ECM), and alternator and all was well.
Old Aug 5, 2008 | 11:40 PM
tell the dealership to check the engine harness. but they might just ignore you, consider there are not many good techs/dealerships out there.
my dealership just replaced mine, cuz there were some short on the 12v wire. cant trace back the short (impossible anyway), so they just replaced it. +1 to my dealership and +1111111111111 to Kevin.
Old Aug 6, 2008 | 06:40 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah i would as y they changed that terminal in the first place..
Old Aug 6, 2008 | 09:38 PM
Nubo's Avatar
Lubricious
Also, make sure the replacement battery has a good charge on it.
Old Aug 7, 2008 | 10:25 PM
Komanji's Avatar
thanks
Well i forgot to mention they replaced the steering rack. I double check all those things. And i took it for a ride yesterday and its not to bad but it does seem alittle slower. I get 13.3vlt at idle and 14.2 at 2k rpm, also volage drops when i turn lights on is that normal? But the batt is still on after about a 20min drive weird.
This is what is crossin my mind. Lemme know what you guys think. When i sent in the alt i didnt tell them what kind of car it was for and i didnt give them my SR pulley and they used one of theres. So im thinkin they might have put the wrong size pulley and got a different reading than it should have... they say i ran out of warr cause time my car has 40,950 miles on it and its a 04, so im not sure. whats goin on.
Old Aug 7, 2008 | 10:35 PM
04RX8man's Avatar
well you should b gettin 13.8 to 14.4 at idle usuallly not at 2k but when u turn aux power on it will drop some but def not alot
Old Aug 7, 2008 | 10:39 PM
Its still over 12.5 volts.
He is still charging.
Try resetting the ECU.
Old Aug 7, 2008 | 10:48 PM
Komanji's Avatar
um
Yea i tried that afew times. at least the brake pedal thing, and disconectin the terminals and touchin them together. is there another way?
Old Aug 8, 2008 | 10:14 AM
Nubo's Avatar
Lubricious
Ok, but you would not be the first one to have their steering rack replaced when the actual culprit is in the upper connector. Seriously, there is a whole thread on this you'd do well to read -- title is "I know this has been covered", or something like that. I had the same problem of the car being harder to turn in one direction than the other. Dealer blew smoke up my butt with wheel alignments, sending me home with the same problem. Eliminating the connector (not just cleaning and reseating) was the 100% cure for me.
TeslaMSI
Dec 10, 2015 01:10 AM
GARCIAC951
Sep 10, 2015 07:17 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
rxwilly8
Sep 2, 2015 02:42 PM
wayloco
Sep 1, 2015 09:03 PM
