Moisture in tailight:
Old Aug 4, 2008 | 08:45 AM
PaPaBear's Avatar
PaPa Bear
The first one replaced was on Mazda. Anyone have this problem and was it difficult to repair doing it yourself?
Attached Thumbnails Moisture in tailight:-att792395.jpg
Old Aug 4, 2008 | 08:48 AM
u're not new, u know the rules
search ! the answers are like everywhere.
Old Aug 4, 2008 | 08:57 AM
RK's Avatar
RK
It's Not Easy Being Green
It's a TSB. If you're out of warranty you just need to buy a new... ?gasket? from Mazda to seal the light or go uber DIY and randomly drill holes in the bottom of your light fixture hoping to get the part where its pooling. The latter method has seen mixed success. The former is advisable. Buy it straight from Mazda.
And NY is right. Search for tail light, taillight condensation, moisture, water, rear light, etc. There's probably at least 10 posts with each spelling asking for help and probably several hundred threads dealing with it.
Old Aug 4, 2008 | 09:56 AM
rled's Avatar
5Picker
There are really good instructions on how to remove your tail light assembly on this site. Mine did the same thing. I bought a new gasket and a tube of clear silicone sealer. When I removed the light I found that the gasket had pulled away from the rear panel allowing water to seep in from the top below the trunk lid. I cleaned it with alcohol and ran a bead of silicone along the top edge where the gasket contacts the panel. I did not drill any holes in my light. If you get it sealed well you don't need weep holes. It has been 2 years and my light is still dry and clear. Good luck..
Old Aug 4, 2008 | 10:34 AM
PaPaBear's Avatar
PaPa Bear
Thank you to all. I will repair as suggested.
Old Aug 7, 2008 | 07:20 PM
Outkast187's Avatar
BTW, the old school Cosmo had open vents in the bottom...
Old Aug 8, 2008 | 11:15 AM
lepichichi's Avatar
I LuV mY Rotary....
i had the same problem and my local mazda dealership replaced it for free
Old Aug 8, 2008 | 12:18 PM
mine was replaced like 4 times, both sides (so total of 8 rear lights assembly)
lol, even with the UPDATED gasket
Joiful
Aug 19, 2007 05:38 PM
nvigor8
19
Mar 28, 2007 03:17 PM
delrmx01
Feb 14, 2006 10:22 PM
sdcrx8
Jan 17, 2005 12:18 PM
Ioman
Jan 18, 2004 04:24 PM
