HOw bad..
Old Aug 2, 2008 | 02:20 PM
CompMan's Avatar
iDüber
HOw bad..
I just noticed I'm 200 miles over my due oil change. During the 3000 miles I put 1 qt of new oil. But its time to get it changed and no where is open right now and they won't take me in for a few days.
I'm trying to not drive the car but its my DD so its kinda hard.
So is it really really hurting the engine?
Old Aug 2, 2008 | 02:37 PM
Go48's Avatar
NO! Don't make it a habit.
Old Aug 2, 2008 | 02:38 PM
StealthTL's Avatar
Metatron
No, even if it gets close to 4k, no harm done.
Don't worry about the small stuff.......
S
Old Aug 2, 2008 | 02:40 PM
CompMan's Avatar
iDüber
Whew! lol This is the first time I ever went a mile over 3k
Thanks guys.
Old Aug 2, 2008 | 04:37 PM
04RX8man's Avatar
Rotary Powered Countryboy
no you are perfectlly fine i have went 4k or more acutally our motors are better to go over in mileage than a regular pison engine becuase we are adding new every oil change but def don't make it a habit
Old Aug 3, 2008 | 10:06 PM
Mugatu's Avatar
Even My Dog Searches
your car will die in exactly 2 days. i'm so sorry for your loss.
Old Aug 3, 2008 | 11:49 PM
I thought is 3 days ?
j/k
u're ok man. jeeze.
Old Aug 4, 2008 | 12:07 AM
DavidR's Avatar
Did you get a phone call saying your motor will die in 7 days? :o lol.
Old Aug 4, 2008 | 08:40 AM
JRichter's Avatar
Void Where Prohibited
Don't sweat it. I change anywhere from 3k - 5k and the manual recommends 7.5k.
Old Aug 4, 2008 | 08:49 AM
PBlue's Avatar
Dial P for Phantom
if the car is new, its bad. the newer it is the earlier you MUST change it.
if youre high mileage its less bad.
the older the engine, the less metal particles in the oil, just make sure you still have oil in there.
Old Aug 4, 2008 | 10:50 AM
kersh4w's Avatar
Hit & Run Magnet
have you ever read your manual?
mazda recommends you change your oil every 7,500 if you have normal driving habits. 5,000 miles if you are a more spirited driver.
Old Aug 4, 2008 | 11:27 AM
xsnipersgox's Avatar
One Shot One Kill
these numbers are really a guideline, it's not a death sentense...
Old Aug 4, 2008 | 11:32 AM
quazmosis's Avatar
Chode
Back in the olden days, you'd be tared and feathered for that kinda behavior.
Old Aug 4, 2008 | 11:50 AM
CompMan's Avatar
iDüber
hahaha
04 with 52k, I just like to change it every 3k.
Thanks for the funny comments though makes me feel better about driving it. Gunna make an appointment now anyways!
Old Aug 4, 2008 | 01:21 PM
dozer's Avatar
on his 3rd rx8
just do it yourself.....5qts at walmart = 11$ plus filter = 3~15$....
Old Aug 4, 2008 | 03:30 PM
04RX8man's Avatar
yeah do it yourself.....but here in FL 5qt's of castrol gtx at walmart is 12$ and 3.83 or so for a filter about 15 bucks and 15 minutes of your time to do it yourself
Old Aug 4, 2008 | 03:38 PM
I do mine a little differently.
After drain, I will close the nut first, pour like a quart of cheap *Shell Full Synthetic* into it first and drain it again. just to get as much crap from the bottom of the pan as possible. then I will change the washer, retighten everything and fill it up with Red Line.
Old Aug 4, 2008 | 04:39 PM
CompMan's Avatar
iDüber
Well I'm gunna get my tranny fluid changed and radiator fluid changed at the same time.
Old Aug 4, 2008 | 04:45 PM
dozer's Avatar
on his 3rd rx8
tranny fluid = redline, only the best for your 8
Old Aug 4, 2008 | 05:24 PM
Icemark's Avatar
sending off samples for testing at every oil change for me has shown that you are wasting money doing oil changes on a Reni at anything under 5000 miles. based on sending oil out for testing; right around 6K miles Castrol 5W30 seems to start loosing viscosity and get to a point that a over concerned RX-8 owner would start to consider a change.
But don't take my word for it. The only way to be sure is to send your oil off for testing.
But unless you have a Turbo or some other forced induction or use crappy oil; you are throwing money away changing the oil and filter at 3K miles.
Old Aug 4, 2008 | 05:27 PM
Deathcraft's Avatar
I'm just speechless!
Rx8manRich
15
Jan 7, 2017 10:32 PM
mikeiscoo2
Jul 23, 2012 08:55 PM
Tamil_Stunna
May 20, 2012 03:30 PM
Dark_Rider2k3
Jan 30, 2012 04:31 PM
