Enkei RS+M wheels
Old Aug 1, 2008 | 03:19 PM
RK's Avatar
RK
It's Not Easy Being Green
Enkei RS+M wheels
Anyone running with these? Tirerack has them in 18x8.5 +35. Between these and the RPF1s as daily driver/autox setup. Can't find any sign that any 8 owners are using these. Closest I can find is a Miata but he doesn't list the offset so I have no idea if they'll have the same, flat look.
http://www.cardomain.com/ride/2327294
Weight and price is close to the RPF1s and I think I like the look more tho I'm hoping to see a few sets of Enkeis in person this weekend to help the decision making.
Old Aug 2, 2008 | 02:06 AM
Endless Rotaries's Avatar
They all have the same look. Spoke architecture doesn't change with that wheel.
I highly doubt weight will be the same as the RPF1 from real time handling senses. Just FYI. I think we have an 18x8 on display so i will look into that.
Also keep in mind that in a 18x8.5 RPF1 it will have different spoke architecture than the 18x9 +35.
8.5 is HI Disk, might be heavier than 9.0" which is LO Disk.
Hope that helps and makes sense.
Old Aug 7, 2008 | 12:08 PM
Sanguine's Avatar
I'm really thinking about getting these wheels too. TireRack recommends 225/45/18s for them but I'm trying to find out if 255/40/18s with fit with the stock suspension and without rolling the fenders in all corners.
Old Aug 7, 2008 | 12:27 PM
Highway8's Avatar
Registered RX8 Nut
Originally Posted by Sanguine
I'm really thinking about getting these wheels too. TireRack recommends 225/45/18s for them but I'm trying to find out if 255/40/18s with fit with the stock suspension without rolling the fenders in all corners.
245/40/18 will be the closest to the stock diameter but the 255/40/18 will give you a little taller gear on the freeway and of course a little wider.
Old Aug 7, 2008 | 12:54 PM
Yes i'd suggest 245/40/18 also with this offset.
Hit me up if you want better than TR pricing for the club.
Rishie
Old Aug 7, 2008 | 01:20 PM
J8635621's Avatar
Pew Pew Pew
255/40 is .2% bigger than stock while 245/40 is 1% smaller. Both very close.
Old Aug 7, 2008 | 01:34 PM
Sanguine's Avatar
Yeah, my amateur number crunching give the stock tire at a 101.25mm sidewall. The 245/40/18 is 98.00 while the 255/40/18 is at 102.00. I'd have to assume the same wheel diameter is the same between the two wheels.
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
duworm
Oct 1, 2015 04:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
