TCS with new rear tires
Old Aug 1, 2008 | 11:47 AM
Teckfall's Avatar
I just got two new Continental ContiExtremeContact tires in the stock size on the stock rims put on by Mavis. I only had two installed both on the rear axle. These tires were put on about 600 miles ago. While keeping the stock Bridgestones on the front. The front tires are probally warn down to 3/32 or 4/32 of tread.
Now the problem is that now while i hit any turn/exit ramp even at speeds well below the posted speed my Traction control kicks in. I first thought it was because the tires were new and needed to be broken in. But they continue to have the same problem. Or is this from having the summer tires in the front, and A/S tires in the rear?
If I take the TCS off then the car handles great, at increased speeds. I now have grandpa on my butt while i take a turn or the TCS gets cranky. Any suggestions will be greatly appreciated.
Old Aug 1, 2008 | 01:58 PM
ur TCS kicks in because it sense different speed.
like u said the front ones are all worn out.(or almost worn out).
when u try to brake, the sensor will be like "wtf the front 2 is not stopping, flap the brakes!"
you should always replace all tires at the same time(and same brand/lineup) to prevent this from happening.
Old Aug 1, 2008 | 04:35 PM
Teckfall's Avatar
I just wanted to make sure that is the reason, I normally would of but money was a little short. I should be getting the fronts within 2 weeks
Old Aug 1, 2008 | 10:09 PM
Stegamasarous's Avatar
Lonely RE Novice
Quieting Grandpa Down
I have had the same issue as well, and I appreciate your response to our comrade's query. Considering I have about 1100 miles on the new set on the back, do you think that the TCS would sense the difference? Would I have to buy an entire new set, basically two to replace the front (at about 1/2 tread) and two to replace the practically new?
Old Aug 2, 2008 | 08:23 AM
VOODOO8's Avatar
Hermitage Holdout
Doubtful, but you'll never know for sure until their installed.
Old Aug 2, 2008 | 04:21 PM
Lonely RE Novice
That is what I am afraid of. I think if my fears are realized any sort of frustration at the situation would be midigated by how impressed I would be at the sensitivity of my 8's TCS.
Cheers.
gwailo
May 14, 2024 06:57 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
20b-3rotor
Sep 2, 2015 08:54 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
