floating the gears
Old Jul 28, 2008 | 07:06 PM
2k4_8's Avatar
floating the gears
So I have a problem. I drive a semi for 8-14 hours a day and I am finding myself shifting without the cluth. Even though I don't grind, is it still bad for the synchros?
Old Jul 28, 2008 | 07:24 PM
climacus's Avatar
If you can float the gears without crunching in this gearbox, you're probably not working the synchros all that hard!
Old Jul 28, 2008 | 07:34 PM
04RX8man's Avatar
Rotary Powered Countryboy
^agree but i would TRY to remember to use the clutch but if your not grinding you can't b doin toooo much damage...
Old Jul 28, 2008 | 07:39 PM
Old Rotor's Avatar
The syncros will resist you putting it in gear if you push them too fast they will tell you.
Old Jul 28, 2008 | 07:54 PM
2k4_8's Avatar
I don't shift fast when I do it simply because I don't shift too fast in the rig either. The synchro's just work for a sec and then it falls into gear... I just wanted to make sure I am not damaging it since I have a very difficult time when I drive a rig around for 10ish hours and I only spend maybe 20 minutes driving to/from work.
Thanks for the swift replies everyone!
theblinkof
Oct 4, 2023 05:24 PM
nowakm99
Oct 9, 2015 07:10 AM
Luke.s
Sep 30, 2015 05:57 PM
Zube6115
Sep 30, 2015 12:57 PM
juicemantwon
Sep 26, 2015 12:30 PM
