Major hesitation in low rpm
Old Jul 24, 2008 | 10:44 AM
RXG8R's Avatar
I have a 2004 RX8 with about 50k miles. I've noticed recently that she is a bit hesitant until I hit 4K rpm, at which that point the powerband kicks in. I had her at the dealer today to check it out and they ran tests but came up with nothing. I have heard several possiblities from people but wanted to hear it from the gurus. Your thoughts and or suggestions are welcome.
Thanks,
Old Jul 24, 2008 | 10:59 AM
CraigRX8's Avatar
CraigRX8
what possibilities where you told
Old Jul 24, 2008 | 11:08 AM
Dont just "oh my car has a problem its hesitating until 4K any ideas what might be the cause ?"
give us the maintenance history of ur car or something.
Old Jul 24, 2008 | 11:25 AM
mysql's Avatar
Doppelgänger
leading coils ftw
Old Jul 24, 2008 | 11:31 AM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Replace your coils. More than likely, thats your problem. And even if it isn't, they should be replaced anyway.
Old Jul 24, 2008 | 11:52 AM
yawn.
Old Jul 24, 2008 | 12:06 PM
RXG8R's Avatar
Well I've had the car since about 10k miles. No mods. I have done all recommended maintanance by Mazda. I drive it about 3-4 times a week in moderate traffic in northeast florida. Typically I hit between 5k and 8k at every shift.
Old Jul 24, 2008 | 12:14 PM
Shnifty's Avatar
Is Nifty
Don't let it get below 4k :D
Old Jul 24, 2008 | 01:50 PM
check coils.
use heavier oil, in ur areas use at least 10w30
Old Jul 24, 2008 | 01:57 PM
quazmosis's Avatar
Chode
Coils yes. Also being the 2nd owner, have you ever had your plugs changed?
Old Jul 24, 2008 | 02:11 PM
04RX8man's Avatar
Rotary Powered Countryboy
coils....but i am also located in FL and notice with even 89 octane gas it does not run right until abot 3k what octane ru running?
Old Jul 24, 2008 | 02:27 PM
RXG8R's Avatar
10w30 it is!
Yes the plugs were changed at about 30k miles but am not sure about the coils.
I am running 93 octane 100% of the time.
Btw thanks for all of the fast replies.
Old Jul 25, 2008 | 08:22 PM
Renesis07's Avatar
Vtak just kicked in yo!!
159 ft lbs torque. Normal.
Old Jul 25, 2008 | 10:16 PM
mike73737's Avatar
^^+1
Old Sep 15, 2008 | 08:04 PM
RXG8R's Avatar
Hey guys. I just wanted to let you know that it was in fact the ignition coils...duh!
Thanks for the advice.
Old Sep 15, 2008 | 08:42 PM
04RX8man's Avatar
way to search!!!! ^^^^
Old Sep 17, 2008 | 06:20 PM
ILoveFI's Avatar
I say we stick a headline on the top of the forums "FOR ALL LACK OF POWER PROBLEMS, LOOK AT YOUR COILS BEFORE ANYTHING"
Old Sep 18, 2008 | 01:09 PM
04RX8man's Avatar
^yes and i still think that all noobs should have like a probation period before they can post like register then a few dozen log ins to search and read then have to take a basic test on some normal ?'s asked by about every noob then they can post we would get rid of alot of these repeat ?'s
Old Sep 18, 2008 | 05:55 PM
Renesis07's Avatar
lol, nah, its kinda fun the flame the noobs every time they ask a 'tard' question
Old Sep 18, 2008 | 06:10 PM
04RX8man's Avatar
^yeah that is true then they get all pissed off and are like "what is your problem I just want an answer and you guys dis everyone" etc haha
Old Sep 19, 2008 | 05:21 AM
XRX8X's Avatar
more then a Mazda
well guys i had no lack of power untill the dealer did the last recall and whohoo!big bad engine problem that caused the engine to hit the dirt and needed to be replaced now i keep getting the 2004 code for a apv motor problem.anyone knowing anything about this please let me know i can't seem to get anywhere with the dealer.2004 6speed G.T.just ms exhaust and k&n drop in .
Old Sep 19, 2008 | 08:39 AM
Renesis07's Avatar
8 year/100K warranty? Are you over 100,000 miles?
Old Dec 17, 2013 | 04:59 PM
ashkan's Avatar
I just wanted to leave a quick reply here since this thread helped me out. I had a similar problem. The car wouldnt start for at least 5-6 seconds of constant cranking every time and i had lost major power specially in lower rpm(anything under5000). It also started to rev really rough when i started the cold after sitting in cold weather (-10, -15). It would start but the needle would play around until it was warmed up which led to the car flooding once. Too cold of a night(-17 with windchill), started her up, went inside and waited for it to warm up. When i came back, the car had turned off and flooded(she turned off because my plugs and ocild were bad so weak spark and extremely cold engine didnt mix). Anyway, back to the main post. I changed my coils, plugs and wires which i bought as a package on ebay for $340. The car now starts like day one. She has also gained her power back and its very very noticeable so if you have similar symptoms(not the flooding), this could be your solution. on a dise note, the package that i bought from ebay is great except for the wires. The wires were too short for some reason and had to order from dealer for $80 butthe coils and plugs are great (so far- 500km)
Old Jan 31, 2017 | 08:20 PM
Riogrande's Avatar
Need help on troubleshooting. My car upon taking off it hesitates then it runs fine. On take off the more I push the accelerator the more it hessitates. Upon take it off and keep it light it runs normal.
Old Feb 5, 2017 | 08:38 AM
Steve Dallas's Avatar
Water Foul
Have you seen this sticky?
https://www.rx8club.com/new-member-f...causes-249529/
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
Nov 5, 2017 09:35 AM
DVerdeyen
Sep 13, 2015 11:19 AM
tgaffner
Sep 7, 2015 08:49 PM
