Kerios
07-24-2008, 07:56 AM
I would like to ask for some advice regarding replacing the ECM in a 2005 MT 192 RX-8. The original ECM was damaged (impact rather than electrical) and I was intending to replace it with another from 2004 MT 192 RX-8.
I understand that the Mazda system has several components in the ECM/Immobiliser system and have the following components from the 2004 doner:
ECM
Keyless Receiver
Keyless Module
Matching Keyfob and keys
Ignition lock and coil
My first query if, I switched over all these components, would the vehicle start? In principle I can't see why it shouldn't (of course the VIN won't match from ECM to car, but I'm not concerned about that), since these components should function as complete system. However perhaps I am wrong?
Secondly, on searching for the Keyless receiver I was unable to find it in the specified places, and finally discovered that in this RX-8 both the Keyless receiver & Keyless Module are combined. While the connectors remain the same, the wiring is slightly different as the host car includes a theft derrent system. I've studied the wiring loom and believe that I can still connect the replacement components I have (linking the receiver and module together with soldered wiring). This is not particulary ideal though, and I wonder if anyone can advise whether this combined keyless unit is the norm now?
Lastly, the preferred option is to solely replace the ECM, keep the original keyless components, keys etc and have the dealer reprogram the ECM. Unfortunately, on speaking to my local dealer, they seem to think that it isn't possible to reuse an ECM from another vehicle and suggest I'll need a new one at a cost of $4000 plus labour! :Eyecrazy:
I've done some searching through the forums and it seems that it should be possible to reuse a secondhand ECM via the i-DS system, can anyone confirm this ?
Is another option to purchase a J2534 pass-thru device plus a subscription to Mazdatech and try and blank/flash the ECM?
I'm in the UK, and the car is a RHD.
Many thanks for your wisedom :)
Mike
ECM
Keyless Receiver
Keyless Module
Mike
