View Full Version : Fix for my door panels
Vasichko
07-19-2008, 04:21 PM
For about 2 months or so my door panels on the arm rest and the handle seem to be very dull and appear to be blotchy.
I have always used Meguiars Vinyl and Rubber protectant.
I just switched to Aerospace 303 to see if this clears the issue up.
Anyone know how to fix this?
Unfortunately I think they are fucked and I may have to buy new panes which sucks cause this is the only spot where this is happening and I take great care of my car.
A picture is attached.
Alucard
07-20-2008, 12:14 AM
truthfully from the picture it just looks like something may have rubbed up against it or someone had something on their hands and it was left on you door...
try this - Lexol Vinylex
and read this...
http://www.properautocare.com/propvincar.html
rx8phase1
07-20-2008, 04:48 AM
same w mine doesnt really bother me though i just put armor all
Nopstnz8
07-23-2008, 11:39 PM
Does anyone know a for sure way to fix this? I have it happening on both door panels and part of the dash. I used Ultima interior shampoo followed by Aerospace 303 and it did make it look a lot better, but it didn't completely go away. What would be the best product to use for the dash and door panels besides what I am currently using? Thanks.
Easy_E1
07-23-2008, 11:42 PM
Looks like a good interior cleaner would fix that up and a vinyl treatment after that. Looks to be just a dirt/oil build up.
Nopstnz8
07-24-2008, 12:25 AM
And what would you suggest?
Vasichko
07-25-2008, 12:22 PM
I would like to know as well.
I did remember seeing some stuff for black vinyl that was a kit for redying / polishing but I dont know if I should try that?
I have used Mequiar's rubber and vinyl clear / condition, Turtle Wax SP20, and now Aerospace 303.
I only applied 303 to one panel to see how it is holding up. Looks to be doing better since I tried that but not completely away. Before I applied the 303 I took a soft bristle tooth brush and water and gave it a light scrub as well.
Nopstnz8
07-25-2008, 12:55 PM
I think the reason the 303 makes it look better is because it acts like it is masking up the spot. If you look closely, it is still there.
onefatsurfer
07-25-2008, 03:28 PM
have you tried back to black?
Vasichko
07-30-2008, 06:49 PM
I dont know, has anyone used this on the interior?
onefatsurfer
07-30-2008, 07:02 PM
I use back to black on the door panels and it works alright. My panels have a few spots where it's pretty white now i guess from the 1st owner's feet hitting it or w/e, but back to black, 303 aerospace, and armor all natural finish detailer don't get it out. suxxxxx
paulmasoner
07-30-2008, 09:55 PM
there are different 303 products, but the one most people have is a protectant. it has no real cleaning properties or restorative ones either. its just a UV protectant, a damn good one.
Nopstnz8
07-31-2008, 02:55 AM
What about 303 fabric and vinyl cleaner?
Nopstnz8
08-02-2008, 10:41 PM
So what will actually fix this? I am starting to get it on the steering wheel and the dash. I really want this to go away because it looks like shit.
Outkast187
08-03-2008, 01:03 AM
IF you keep adding protectant, it just seals in it more and more. You need to actually clean it, sometimes warm soapy water works wonders. Baby oil is another alternative, but I just keep my clean with nothing else on it. Mine is still perfect, no spots. I dont think anything will fix it, just hide it honestly.
9krpmrx8
08-03-2008, 01:24 AM
Dude, just clean it with dawn and re-apply a good protectant. You will be good to go.
Nopstnz8
08-03-2008, 03:42 AM
Yeah I know. I cleaned it with plain water then used ultima interior shampoo, followed by 303 protectant. It partially covered it, but now the spots are back.
Nopstnz8
08-03-2008, 03:43 AM
Won't dawn ruin the sheen of the plastic?
Outkast187
08-03-2008, 09:20 AM
No, dawn wont hurt the plastic at all. I have done it personally hundreds of times. Try cleaning it and give it a couple days without protectant...see it the spots return.
Just take a warm bucket of water, just a little dawn to make the water sudsy and wipe it down, then rinse with clean water.
Nopstnz8
08-04-2008, 03:48 AM
I have been researching and most detailing websites say specifically to not use stuff like dawn. What is another alternative, if there is one? I want a for sure way to fix this because I would like to tackle the problem tomorrow. Thanks.
Outkast187
08-04-2008, 08:59 AM
carwash soap, etc. works also. Dove soap is probably the safest of any of them.
Vasichko
08-04-2008, 11:45 AM
Any luck?
luis@championsmotorsports
08-04-2008, 12:36 PM
if you have a motorcycle shop near by i have and still use silcolean pro prep it works great..
Outkast187
08-04-2008, 10:28 PM
I'm tellin ya, you guys are thinking too much....I use dawn on no less than 30 cars...my shit doesnt have blotches. You are using high dollar super stuff, and you are having issues....do the math. I used it on the rx8 specifically. Test on back panel where you cant see it, or in the trunk if you wanna make sure it doesnt melt away or something.
Nopstnz8
08-07-2008, 02:28 PM
Ok I clean the interior plastics with dawn then applied 303. It looks better, but I couldn't tell since it was dark in the garage. I will let you guys know later.
Nopstnz8
08-08-2008, 01:48 AM
Honestly, I can't tell for sure if it is gone, but it looks a lot better. The dawn removed all the build up and now the 303 doesn't feel greasy. It also looks better. In the sunlight, I think you could partially see it, but it would easily go unnoticed to people who didn't previously know about it.
Thanks for the dawn suggestion Outkast187! It went very well. I also read the link which Alucard posted and it stated that alkaline soaps would be fine. That is why I went through with the dawn procedure.
EdwardsB
08-08-2008, 12:40 PM
I just use armor all and reapply when it wears off from my arm resting there...I also use a fold up sunshade for my dash as well as armor all.
BRGREEN8
08-09-2008, 03:21 PM
good to hear dawn works without damaging the plastics.
