For RX-8: what happens if you pour in too much oil?
Old Jul 18, 2008 | 09:08 PM
R3I00's Avatar
I couldn't seem to find an answer to this question anywhere on the site... or maybe I just suck at searching >.>
Anyways I've been wondering, what will happen if you pour in too much oil, like 0.5qt - 1qt more? Any input is appreciated =)
Old Jul 18, 2008 | 11:22 PM
juikster's Avatar
Im 8 drifting on a budget
Do you mean in an RX8 or just .5 in any motor? I don't see it causing much but you can easily drain it out until you got it right. my son added 2 qts. over in his 99 Isuzu Rodeo and that caused the motor to sputter real bad like it was about to lock up, so drain it down to normal and you should be fine.
Old Jul 18, 2008 | 11:28 PM
R3I00's Avatar
ya I heard for piston engines overfilling causes problems in the engine and gaskets, but don't know what the consequences are for rotaries...
Old Jul 18, 2008 | 11:40 PM
SleepeR1st's Avatar
Overfilling of a piston engine causes foaming/frothing of the oil. Overfilling on a rotary engine probably wouldn't harm anything. Nothing moves in the oil pan, the bottom of the engine is sealed off.
Old Jul 19, 2008 | 12:40 AM
juikster's Avatar
Good point Sleep1, I wasn,t sure about the effects in the rotories....
Old Jul 19, 2008 | 01:33 AM
ken-x8's Avatar
Half a quart won't hurt anything.
At some point of overfill, however, the Renesis will start sucking oil into the intake through the breather. When that happens, you'll get an oil soaked air filter and likely an oil contaminated mass air sensor. There have been quite a few posts on that problem.
Ken
Old Feb 17, 2010 | 03:06 AM
apoc_reg's Avatar
Can you point me to those posts? I think mines overfilled but not sure how to drain!?
Old Feb 17, 2010 | 03:58 AM
PeteInLongBeach's Avatar
You are not sure how to drain oil? Either make a mess with intermittant removals of the drain plug, or suction it out through the dipstick tube. There are a variety of transfer pumps made for that purpose. Google it or check amazon.com .
Old Feb 17, 2010 | 04:01 AM
apoc_reg's Avatar
THe suction method sounds like a winner! Thanks
Old Feb 17, 2010 | 05:05 AM
robrecht's Avatar
Clean the MAF sensor (easier) or it may hurt your gas mileage.
Old Feb 17, 2010 | 05:37 AM
mdr's Avatar
mdr
Depends on how much you overfill it by and how long you leave it like that.
On a rotary it can be as bad or worse than a piston if left long enough or with too much.
It can clog up the MAS and if left long enough it can clog and cause the SSV (Secondary Shutter Valve) to stick as well as cause apex seals to stick.
.5 a qt will probably not hurt much for a short time 1 qt you are pushing it.
Old Feb 17, 2010 | 06:01 AM
apoc_reg's Avatar
Thanks guys, i'll look into how to clean the MAF sensor.
Anyone know how a .5 qt translates to litres?! I've not heard the expression before (probably because im english) thanks
edt: i have brought a pump extractor so i shalt use the car until it arrives. Ta
Old Feb 17, 2010 | 06:22 AM
JinDesu's Avatar
went back to srsly broke
A liter is slightly more than a quart. For the engine oil purposes, you can assume a liter is a quart.
Old Feb 17, 2010 | 08:52 AM
ken-x8's Avatar
English? Half a quart is a pint.
FWIW, my 8 has been overfilled up to the top of the flat on the dipstick with no harm.
Ken
Old Feb 17, 2010 | 09:52 AM
treaven20's Avatar
I be like YUUUPPP!!!
over-filling can cause one big problem... a mess that is a pain in the a** to clean. thats about it.
Old Mar 5, 2010 | 03:34 PM
SheffieldSteel's Avatar
Intended acceleration
Ken
Half a quart is a US pint (16 fl oz), not to be confused with an Imperial pint (20 fl oz, or 543ml).
Old Mar 6, 2010 | 08:14 PM
zoomman's Avatar
a buddy of mine did it and he put 2 qts extra in. It sounded like the motor was drowning, like it was all in the chambers. it spit it out the intake and out the exhaust like an old beat up truck would with blow by. Its not pretty. He had it drained quickly, but likely did damage to his cat, had to replace his k&N and had to clean his MAF.
Old Mar 7, 2010 | 01:11 PM
xsnipersgox's Avatar
One Shot One Kill
just always replace oil with quart containers, or be careful on the last quart, the dipstick is not linear i think. overfilling it by .5 quart can save you the trouble of topping off every other fillup.
Old Mar 7, 2010 | 08:11 PM
04RX8man's Avatar
Rotary Powered Countryboy
half is fine...more than half a quart i'd take some out just so you don't coat your MAF...it's a PITA to clean....trust me i've had to do it and not because of overfilling...
Old Mar 8, 2010 | 11:46 AM
Silverisk8's Avatar
u dont want to do that, I know i did to mine and i started seeing oil spots each time i parked, I actually dumped 5qt when it should be only 4 1/2 qt, as for the effects and possible damages of some engine parts I have no clue since I drained 1qt in between 2 days top after that stupid mistake
Old Mar 8, 2010 | 03:38 PM
Aseras's Avatar
in the rx8 all it does is end up in your airbox clogging the MAF sensor.
Old Mar 9, 2010 | 10:07 AM
Silverisk8's Avatar
yeah ASERAS is right ... that too happens...
Old Oct 12, 2013 | 03:24 AM
FuzzeH's Avatar
would an oil catch can prevent any overfill from reaching the MAF? I emptied an entire 5 qt jug without even thinking to check how far I filled it to. After the oil settles it reads at the to of the flat part of the dipstick (less than a centimeter over the full line).
Old Oct 12, 2013 | 09:07 AM
ken-x8's Avatar
Like I said back in '10, mine has been filled to the top of the flat a number of times with no harm.
I've got an '06. It's my understanding that '06s were less prone to sucking excess oil into the intake than most other years. Something about the breather being configured slightly differently. There may be info on that in the various catch can threads.
Five quarts sounds like a lot. Unless you tipped the car to get oil out of the coolers, I think it usually takes about four to fill it.
Ken
Old Oct 23, 2013 | 10:13 AM
Supernaut6's Avatar
Did the spots come from the oil pan?
