Trans Cooler Question
Old Jun 27, 2008 | 10:17 PM
Silver_Surfer's Avatar
I4NI
How do most of you guys hook up your cooler. Do you still have it running through the radiator or by-passed it completely? Would bypassing the radiator make your engine run cooler? Or do you have both radiator and cooler hooked up together?
Old Jun 27, 2008 | 10:57 PM
nuke0907's Avatar
Never Blend In
you should get these, radiator insulator and oil bypass kit.
Old Jun 28, 2008 | 03:33 AM
I4NI
Looks like the Radiator insulator is used is cold climates and the Oil by-pass kit is used to cool things down in hot climates. I live in a HOT climate.
Old Jun 28, 2008 | 08:40 AM
nuke0907's Avatar
Never Blend In
that question made me laugh. i just couldn't resist.
just leave it the way it is, or get the BHR radiator.
Old Jun 28, 2008 | 09:33 AM
09Factor's Avatar
Original Turbo 'd Auto !!
There is a tranny cooler DIY i did (shameless plug).
And / or get the BHR Radiator. Really helped in the Az heat.
Old Jun 28, 2008 | 02:43 PM
I4NI
Did you read the whole thread or only that one sentence?
Do most people hook up there after market trans cooler(The one that goes in the front of the radiator/AC condenser) and still use the oem cooler(In the radiator) or just disconnect the oem cooler and just use the after market trans cooler?
Old Jun 28, 2008 | 03:46 PM
I4NI
Thanks I cant seem to find it
Old Jun 29, 2008 | 03:11 PM
09Factor's Avatar
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-cooler-install-112522/
I believe that most would plumb the aftermarket cooler in after the OEM at cooler. You can do it either way really.
Old Jun 30, 2008 | 01:54 AM
I4NI
https://www.rx8club.com/showthread.php?t=112522
Thanks for the link!
I was just wondering if I just ran the after market cooler alone then all the radiator would have to do was cool water and not both ATF and coolant.
Old Jun 30, 2008 | 07:39 AM
09Factor's Avatar
I would suggest one plumb the aftermarket trans fluid cooler in AFTER the radiator as this will allow the factory rad to assume most of the cooling duties of the trans fluid while the external cooler can pick up the rest. IIRC, it is the passenger side trans hose that is the return to the transmission but I could be wrong. Might you remember, 09?
ON your radiator that is correct. I don't remember if that is the same setup the oem rad uses.
Old Jun 30, 2008 | 11:30 AM
I4NI
Thats the information I needed!!!! Thanks Guys!
Old Jul 2, 2008 | 01:43 PM
hoy's Avatar
hoy
i recently purchased a 05 at. the dealer told me 212hp ,after further research he lied basically im pissed,very happy with the car. just need to add some hp which seems nearly impossible without Fi. I have a heymee (sp) transmission cooler i was wondering if that woulf fit the at 8 thanks guys, obviously a rotary noob.I am going to call mazda about the misinformed info provided by the salesman im sure nothing will come of it.Any suggestions would be greatly appreciated for hp gains with, the cobb ,midpipe ,exhaust,intake and possibly a pully ??
Old Jul 2, 2008 | 01:45 PM
mysql's Avatar
Doppelgänger
hp != whp
Everyone here will talk about whp since that's what we can measure. Manufacturers all talk about hp, which is before drive train losses.
Old Jul 2, 2008 | 05:20 PM
hoy's Avatar
hoy
Originally Posted by mysql
hp != whp
right but i just think the salesman should have known the 212hp is in the 6port o6 models.i love the car just needs some more umph off the line,and 2nd gear is tall as hell.Any mod input would be greatly appreciated!
Old Jul 16, 2008 | 10:16 PM
sosonic's Avatar
I will show some love. Here are pics of how mine is setup.
It is a Re-amemiya AT cooler (I suggest buying a cheaper one) that is custom mounted in the front. However, a BHR radiator should work well too.
Attached Thumbnails Trans Cooler Question-photo-0183.jpg   Trans Cooler Question-photo-0184.jpg
Old Jul 17, 2008 | 02:34 AM
09Factor's Avatar
09 Factor and rx82hate may not like hearing this but;
The BHR A/T radiator has been updated with a slightly larger tranny cooler section and 1/4" NPT fittings at no extra charge.
No not really. I'm just happy to know some of my testing lead to this change for the better.
RXFEVER
Aug 29, 2018 10:14 AM
9krpmrx8
Oct 13, 2015 01:36 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
Sakebomb Garage
Sakebomb Garage
Sep 6, 2015 03:29 PM
