E-Brake Light wont' shut off
Old Jun 26, 2008 | 04:14 PM
legendkurado's Avatar
I'm not too sure what happened with the wiring of the E-Brake, but right now when the Ebrake is off, the light still remains on. Wanted to know if anyone else had this problem or experience, and if there is a certain fix for it. Thanks ahead of time
Old Jun 26, 2008 | 06:06 PM
samyv2's Avatar
Yes, I had the same issue. But once I got my front brake pads replaced, they were almost completely gone the light went away and has never been on since.
Old Jun 26, 2008 | 06:34 PM
could be the brakes as samyv2 mentioned or you could be low on brake fluid.
Old Aug 3, 2008 | 04:52 PM
hmm.. it defnitely wasn't the brake fluid i guess i'll change the brakes and see what happens
Old Aug 3, 2008 | 06:06 PM
04RX8man's Avatar
Rotary Powered Countryboy
or possible the button under the center console that gets pressed/depresseed witht that handle got stuck somehow or disconnected I would check that before goin to change brakes especially if you don't need them
Old Aug 3, 2008 | 06:11 PM
invasion08's Avatar
Ckeck the Brake Fluild and see if it is at max. Changing the front pads will not affect your e-brake in any way shape or form the e-brake is connected to the rear not the front. Do you use the e-brake a lot if not pull up on it hard a few times maybe something is getting stuck.
Old Mar 28, 2010 | 05:25 PM
JantzenRX-8's Avatar
Bump.
I just had the e-brake light problem starting yesterday and i just wanted to confirm that, much to my surprise, topping off the brake fluid worked.
I punished my brakes pretty hard at the track yesterday and i thought i broke something but it just needed a couple ounces of fluid. FYI.
P.S. - where does brake fluid go? As far as i know i don't have any leaks but its strange how it just disappears
Old Mar 28, 2010 | 07:53 PM
ken-x8's Avatar
The same place as socks that are put into dryers.
Or maybe it goes into the caliper bores as the pads wear down.
Ken
TeslaMSI
Dec 10, 2015 01:10 AM
CARBONRX-8
Oct 5, 2015 03:46 PM
Emmanyei
Sep 4, 2015 11:38 PM
