Help!! Car Wont Start
Old Jun 21, 2008 | 01:36 AM
m3pkrobert's Avatar
Unhappy Help!! Car Wont Start
today i went to visit some friends i drove for about 30 min, i stayed there for
2 hours i get out to come back home and the car wont start, the whole
lighting works, and i also charged the battery with another car but
is not working, i just hear the "CLICK'' not even the engine trying to
start, just that click sound, hope someone can tell me what this can be
thank you.
Old Jun 21, 2008 | 01:50 AM
philsbluerx8's Avatar
starter? coils? spark plugs?
Old Jun 21, 2008 | 02:28 AM
Jon316G's Avatar
Grasshopper
If all you hear is a click and the engine doesn't even turn (but the internal lights are illuminating and not slowly dimming away), I would start checking fuses (the fuse box in the engine compartment) and also see if any of the relays look burnt/deformed (they simply pull out with a little wiggle).
FYI... Always best to disconnect the negative terminal battery when removing fuses and relays...
although I am guilty of doing it without killing power, even at work to our surface mount equipment
Old Jun 21, 2008 | 06:26 AM
Go48's Avatar
Sounds like the starter is not getting correct power. Check battery cable connections at the battery and at the starter, and also check grounding points. Something may have worked loose over time. Fully charge the battery and try again.
Otherwise, if the car is still under warranty, have the dealer pick it up and check it out.
Old Jun 21, 2008 | 07:33 AM
m3pkrobert's Avatar
thanks, i already called the dealer, but my car is not under warranty nomore
Old Jun 21, 2008 | 07:50 AM
check fuse ?
Old Jun 21, 2008 | 08:00 AM
m3pkrobert's Avatar
i havent check fuses cause the car is not in my house and i came to sleep to my house but im going back in 30 min ill try that first before have it towe it
Old Jun 21, 2008 | 08:01 AM
check it, I bet it is.
m3pkrobert's Avatar
BTW i had oil change last week, i read that it my be something related with that, but im not sure
Old Jun 21, 2008 | 08:03 AM
Jon316G's Avatar
Grasshopper
If you overfilled your oil, it'll run into your intake through a breather hose.
But the engine should still attempt to turn!
Old Jun 21, 2008 | 12:23 PM
m3pkrobert's Avatar
dammm i went to the dealer they said is the starter, and they charging me $722 for the part and installation and if after that the ingene dont start they will do a
de-flooding for $425, wow thats really fu*k up, i was saving money for my new wheels, but money is gone
Old Jun 21, 2008 | 12:27 PM
Jon316G's Avatar
Grasshopper
$425 to de-flood an engine
Old Jun 21, 2008 | 12:36 PM
m3pkrobert's Avatar
i know their fu*king crazy
Old Jun 23, 2008 | 04:46 PM
designerman's Avatar
Get a new car. RX-8 sucks. Mazda is too cheap and lazy to fix the engine problem. Instead they keep patching it with warranty extensions. I dumped mine at the first extended warranty of 60,000 miles after repeated failures at fixing the problem. They can't even track the fact I don't have the car anymore. Recently got another warranty extension notice that they are giving now to 100,000 miles. Worst car I ever had. Kaboom !!!
Old Jun 23, 2008 | 04:52 PM
xsnipersgox's Avatar
One Shot One Kill
get the starter installed, skip the deflood, SPECIFICALLY tell them to not do anything unless authorized by you. all decisions goes through you. you can do the deflood yourself if need be (push start will solve the problem if the starter will work) you can probably acquire the parts cheaper online, and hand it to them for less if you will wait.
marc2820
Jul 26, 2015 10:47 PM
dbarber
Jul 25, 2015 01:34 PM
T_Mags
Jul 24, 2015 11:29 AM
Bamaham
Jul 23, 2015 08:08 AM
Kangarhew
Jul 18, 2015 08:27 PM
