Sqeaks will not go away.
Old Jun 20, 2008 | 10:44 PM
Vasichko's Avatar
Ok so about 5 months ago I brought my car in for a sqeaking bearing in the clutch.
While there I had Mazda install my ACT clutch and flywheel for free.
Bearing starts making noise again.
2 day ago I take it to the dealer.
They replaced pilot bearing, clutch release collar, bearing needle, and an oil seal.
I picked it up at noon and after work when my foot isnt on the clutch the squeaking noise is worse then is was before but goes away when I push the clutch in.
Anyone have an idea of what this could be because it is ******* driving me nuts.
Old Jun 21, 2008 | 06:30 AM
Go48's Avatar
When does it squeak? Continuously with the clutch engaged (i.e., pedal out), or only when the clutch pedal is depressed?
Old Jun 21, 2008 | 09:20 AM
Vasichko's Avatar
It squeaks continuously when the pedal is out.
Old Jun 21, 2008 | 10:49 AM
Go48's Avatar
Hmmm, probably not a throwout bearing then. Assuming they did, in fact, replace those bearings, I suppose it could be an internal transmission bearing. In any case, you will likely have to take it back to the dealer for a diagnosis/fix. I hope you are still under warranty.
Old Jun 21, 2008 | 11:00 AM
Vasichko's Avatar
I also noticed when driving spirited, as soon as I engage the clutch at high rpms I hear a squeal when it engages.
Is there any possibility that the clutch is not adjusted properly and the clutch isnt fully engaging?
Old Jun 21, 2008 | 11:08 AM
Go48's Avatar
Don't know about that. Does it squeak when idling in neutral with the pedal out? Then when you depress the pedal it goes away?
Old Jun 21, 2008 | 12:22 PM
Vasichko's Avatar
yeah
also when accelerating mildly you can gradually hear it increase, yet when doing that if i barely put any pressure on the clutch it doesnt make a noise.
Old Jun 21, 2008 | 04:29 PM
Go48's Avatar
yeah
Could be the transmission main shaft bearing, although I believe those are ball bearings and I wouldn't think they would make a squeaking sound when failing. As a last resort, remove the fill plug on the side of the transmission and check the fluid to see if it is full and of a good color.
Old Jun 21, 2008 | 10:03 PM
Vasichko's Avatar
I replaced the tranny fluid about 7k miles ago, it should be fine.
Old Jun 21, 2008 | 10:10 PM
get them to check the alignment of the ppf.
Old Jun 23, 2008 | 10:19 AM
Vasichko's Avatar
You think this would cause a problem.
From looking at it, the PFF looks like it is spot on.
Old Jun 23, 2008 | 11:21 AM
yes,
i know it will. got the tshirt.
you cant look at the ppf and tell. you have to measure it..
Old Jun 24, 2008 | 12:19 PM
Vasichko's Avatar
Is it possible that I need to adjust the clutch engagement/disengagement point?
Maybe when its engaged it is not fully engaging?
Old Jun 24, 2008 | 10:27 PM
read this and see if it fits.
http://www.finishlineperformance.com...11-06-1724.pdf
Old Jun 25, 2008 | 09:09 AM
Vasichko's Avatar
I do have that but that doesnt bother me.
I get a noise that sounds like a cricket chirping when idling and the car is in neutral. So if Im sitting at a red light in neutral the squeaks are there the whole time. The noise gets a bit louder when slowly accelerating.
This only happens when the clutch is engaged, when I press the clutch in and hold it goes away.
Old Jun 25, 2008 | 11:31 PM
wow,
that sounds a bit like the pga guys problem. i would have the ppf checked. because you dont want to know what turned out to be his issue.
no vibrations? correct.
Old Jun 26, 2008 | 10:02 AM
Vasichko's Avatar
PGA issue?
The dealer just called and said its because my ACT clutch is putting too much pressure on the throwout bearing. They said I can go back to OEM clutch or just deal with the noise.
Old Jun 26, 2008 | 11:28 AM
ROFL
Tell ur dealership that they can suck it.
I had ACT clutch b4 and MINE HAD NO NOISE AS LONG AS MY FOOT IS OFF THE PEDAL.
Just deal with the noise ? how about *Let me get my money back for the install* sound to them.
if they cant do it right, they shouldnt even touch it in the first place.
Old Jun 26, 2008 | 02:13 PM
Vasichko's Avatar
Yeah now I picked it up today, I dont know if it is from my Axial Flow SS but in between shifts there is a noticeable tranny whine.
Im really just about to trade the car in, take my losses and do what I shouldve done in the first place and buy a Honda.
Old Jun 27, 2008 | 01:41 AM
you get tranny whine while in gear!!! in between shifts i dont know what your are talking about, tends to be quiet..
your are all over the place on this issue..
what oil are you running in the transmission?
Old Jun 27, 2008 | 09:45 AM
Vasichko's Avatar
75w90.
I had MT90 in there but I felt it was too notchy when cold.
Old Jun 27, 2008 | 09:47 AM
Vasichko's Avatar
Sorry I have just lost trust in the dealers around here. Everytime they work on it, its a new issue.
Had to take the console apart and reconnect the buttons for the heated seats since they forgot to plug them in.
Old Jun 27, 2008 | 09:48 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Idiots!
That's why I do 95% of the stuff myself!
Old Jun 27, 2008 | 04:35 PM
Vasichko's Avatar
Im wondering if it could be the clutch not fully engaging creating the squeal?
Would adjusting the clutch pedal do anything?
Old Jun 27, 2008 | 07:34 PM
not likely,
but try it.. you need a 10 and a 12 mm wrench.
