CEL after using SeaFoam Engine Cleaner
Old Jun 19, 2008 | 12:28 AM
PoLaK's Avatar
Son what is your Alibi?
Hit 50,000 not too long ago I drive far from a granny, in-fact when dealerships were testing for engine recalls about 1.5 years ago I got the best bill of health out of any Rx-8 they tested, but figured that it would be good to clean her out anyway.
First I just sucked up 2 ounces of fluid into each rotor housings using the 2 nipples on the side of the lower intake manifold with the car running with someone keeping the revs up. First housing went fine, second housing triggered a CEL.
Tried to start 3 times to clear the CEL once the smoke stopped billowing and the idle stabilized, but no such luck, reset the ECU too to no avail.
Read up on here on the process of cleaning by disconnecting the ESS and cranking the fluid into the chambers through each nipple then letting it sit for a bit than reconnecting the ESS and starting again. Doing this the CEL light flickered and I thought it was about to go away while the car was clearing the smoke out the tailpiple but then it stayed on again.
Ideas on what could be the problem ?
Old Jun 19, 2008 | 06:03 PM
PoLaK's Avatar
dirty o2 sensor?
Old Jun 19, 2008 | 06:21 PM
whenson417's Avatar
Do you know what the code is?
Old Jun 19, 2008 | 06:23 PM
I put two cans through mine, but disconnected the cat pipe from the exhaust manifold before doing so. Most of the fluid ran right through the engine, into the exhaust manifold, and then out onto the garage floor. I left the cat pipe disconnected through the process of firing it up after the soak period and blowing out huge clouds of white smoke for 20 minutes.
More than likely you fouled your cat or O2 sensor by leaving it all hooked up however I've run 1 can mixed in 5 gallons of fuel through it several times since without issue you really need to pull the code in order to assess what the problem might be
PoLaK's Avatar
no sir don't have a way of pulling the code as of now.
Old Jun 19, 2008 | 06:37 PM
Polak, you noob! It's quite common to get it afterwards.
I did this to two cars on the same day, one got a CEL, mine didn't. Others have reported the same thing. (see Nycgps's DIY thread)
Old Jun 19, 2008 | 06:41 PM
PoLaK's Avatar
heres the bong in the cat what do you think? Ignore the threads they've been like that since I took it out too hot once during a clutch flywheel swap 2.5 years ago.
Attached Thumbnails CEL after using SeaFoam Engine Cleaner-img_9088.jpg   CEL after using SeaFoam Engine Cleaner-img_9089.jpg
PoLaK's Avatar
alright so whats the solution, can't blame me i've been out of the loop for a bit.
Old Jun 19, 2008 | 06:45 PM
I'm just messin' with ya.
Unfortunately the solution requires something you don't have at the moment. Gotta pull the code.
The car I did this to therw two CEL's. One was E-shaft related, forgot the 2nd. Just zapped them with the scanalyzer.
Old Jun 19, 2008 | 07:34 PM
PoLaK's Avatar
don't all cels clear after you clear the sensor memory with the 20 brake pump assuming the problem with the sensor no longer exists?
Old Jun 19, 2008 | 07:48 PM
no ... scan tool or you can disconnect the battery overnight
Old Jun 19, 2008 | 07:55 PM
PoLaK's Avatar
Time to make use of that nifty master switch i just installed
Old Jun 19, 2008 | 11:31 PM
good luck...........
I think it's a simple misfire
Old Jun 20, 2008 | 01:24 AM
PoLaK's Avatar
cleared, i'm guessing misfire as well due to the blinking on the second occasion.
Old Jun 20, 2008 | 01:39 AM
MazdaManiac's Avatar
Misfire.
vapor2
Nov 3, 2020 03:38 PM
UHATEIT
Mar 31, 2019 05:31 PM
uZu
Dec 30, 2015 12:35 PM
rotorsnsaabs
Aug 26, 2015 08:21 PM
dbarber
Jul 25, 2015 01:34 PM
