Locking lug nuts
Old Jun 16, 2008 | 02:10 PM
Jasonawojo's Avatar
Locking lug nuts
Hey, quick question.
Somehow I bent my lug nut key so it doesn't fit. Are the keys all the same between the RX-8s?
Old Jun 16, 2008 | 05:58 PM
midlife crisis's Avatar
No, they are not.
Old Jun 16, 2008 | 06:09 PM
not the same, if you registered your locks you can get another key
Old Jun 16, 2008 | 06:10 PM
dozer's Avatar
on his 3rd rx8
^whats the cost???i lost mine and i totally forgot to ask the same question
Old Jun 16, 2008 | 06:31 PM
xsnipersgox's Avatar
One Shot One Kill
14 bucks now.
Old Jun 16, 2008 | 06:54 PM
Juice's Avatar
I made some poos
Easiest thing to do is either buy the tool to remove them yourself, or go to a wheel/tire place and have them do it for you. I decided to buy the tool and it cost around 40 dollars, 1 tool to remove the locking nuts and 1 to remove regular lug nuts that have been stripped. Plus, I now have the tools to do it if it ever happens again.
Here is a link:
https://www.wescotools.com/p-4974-tw...al-system.aspx
Old Jun 16, 2008 | 08:41 PM
sumdeus's Avatar
I hate locking lug nuts. Same thing happened to me; I eventually got mine off (went to a shop) and replaced them with normal lug nuts.
Old Jun 16, 2008 | 08:53 PM
Smoke Honda's Avatar
Mid-Boss
The 8's locking nuts suck ***. There should be a sticky in this forum just to tell people that is should be the first wheel upgrade you should get.
Old Jun 16, 2008 | 09:09 PM
Jasonawojo's Avatar
Can you clarify on that Jedi? I'm not the original owner so I wouldn't know. I looked online and you can buy a set of 4 locking nuts and a key for $32 from Onlinemazdaparts, so it seems strange that every one would be different.
DarkBrew's Avatar
Extraordinary Engineering
Get something like this
http://store.summitracing.com/egnsea...&y=0&N=700+115
Old Jun 16, 2008 | 09:11 PM
mysql's Avatar
Doppelgänger
There's only around 8 different locks. Just go to your dealer and see if they have a master lock.
I love my McGard spline lugs: http://www.pdm-racing.com/products/mcgard.htm
The lugs are two piece, so the bottom part that touches the rim doesn't spin and grind into the rim as you tighten.
Old Jun 18, 2008 | 05:10 PM
Jasonawojo's Avatar
I ended up just ordering a new key at the dealer. They have a set that the techs use and will come and see which one fits if you need to order a new one. The local dealer wanted about ~$24 for the key though, so if you had the tool to remove them without key, or wanted new locking nuts, it would make fiscal sense to do that instead. The dealer orders them from the company that makes them, not Mazda, fyi.
cliffkemp
Dec 24, 2024 10:48 AM
200.mph
Dec 10, 2018 03:49 PM
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
Evan Gray
Sep 26, 2015 12:30 PM
RXBae
Sep 14, 2015 03:54 AM
