any help appreciated
Old Jun 14, 2008 | 07:06 PM
j12tse's Avatar
Had my Rex 2 years now, it's been superb, 2004 only 27000 miles on clock, recently I put too much oil in and it held back at 6000k revs just the once, i quickly got some oil out and it never did this again, however it did start idling much worse than it used too, admittingly i havn't had the bottom housing of the air box fitted for some time, (it broke - one on order now.) The idling is still really not too great and I wondered if when I re-fit the housing if it will help as Im wondering if the extra heat is effecting the MAF? I have cleaned the MAF by the way. Im wondering also if it may be the engine mounts but Im really not sure how bad the idling would need to be. Also when stood idling I can hear a slight 'dik dik dik dik' coming from the engine, if i put the clutch in (to make it quieter) and listen under the car i can hear it quite well? is this a normal sound or does anyone have any ideas whats wrong with my car??? It runs perfect and better than ever when moving just not on idle?? please help, Dan
Old Jun 14, 2008 | 08:28 PM
daisuke's Avatar
rotorized!!!
check the fit of your spark plug wires
Old Jun 14, 2008 | 08:33 PM
BoosTED's Avatar
Well, it is still under warranty, bring it in to your local Mazda service department.
Old Jun 15, 2008 | 12:58 AM
Spinning Sushi's Avatar
I <3 Sushi
The sound that the transmission makes when the clutch is depressed is caused by your throw-out bearing. That's a normal thing; almost half of the 8 community on this site have this problem. It won't effect your performance.
Old Jun 15, 2008 | 09:34 AM
VOODOO8's Avatar
Hermitage Holdout
Quick check for oil blowback into the air intake system - filter box to engine might reveal something. You noted you cleaned the MAF after the oil overfill but it might have gotten contaminated again from oil getting in where it doesn't belong.
Old Jun 16, 2008 | 03:07 PM
j12tse's Avatar
Hi guys, i know about the clutch noise, i just meant with it pressed you could hear more, there was oil in the air pipe but i cleaned the maf after that??
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Michael Bryant
Oct 12, 2015 03:07 PM
Digitz0070
Oct 7, 2015 12:43 PM
Racingjunkie
Sep 29, 2015 05:05 PM
Jb4ker96
Sep 27, 2015 10:06 PM
