Footman
06-12-2008, 07:34 PM
I am seeking some expertise on suspension to explain to me some stuff.
I'm thinking of going with the Tein S-tech lowering springs using the stock shocks. Lots of people are saying using lowering springs without changing the stock shocks will kill the shock faster. The either recommend aftermarket shocks or coilover kits.
To my understanding, the reason the S-tech + stock shock combo will kill the shocks is because the S-tech's stiffness is higher than the stock spring, and that stiffness is not matched to the shock. Correct me if I'm wrong here...
If this is the case, how will getting aftermarket shocks like the Tokico D-spec or Koni-yellows be any better? Aren't those shocks also designed for a particular spring rate?
i.e. Take the S-tech + Tokico combo. The Tokico's have adjustable dampening, but not adjustable ride height, so the height is determined by the S-tech. If you choose a dampening level that is either too low or too high, then wouldn't that be the same effect as you using the S-tech + stock shocks?
Coilovers that have adjustable height only such as the Tein Basic, vary the height by changing the compression of the spring on the threaded support on the bottom. If I change the height to maximum low, then the spring would be stiffest already, and if I change the height to maximum height, then the spring would be softest. In either case, the shock is not adjustable, so the shock somehow has to compensate for all the possible stiffness adjustments the spring can be set and still be "okay"? Because at some point, wouldn't it run into the situation of having the spring too stiff mismatched to stock shocks and killing them?
Please someone educate me, as this has been confusing for me.
