Tach Visability Problem When Sunlight Hits It
Old Jun 12, 2008 | 03:22 PM
Nopstnz8's Avatar
Question Tach Visability Problem When Sunlight Hits It
Hey guys... I am having a problem and was wondering if anyone can help me? When I am driving with all the windows down and the sunroof open and sunlight hits the tach, I can't see how fast I am going. Once the sunlight isn't hitting it, I can see it fine. Does anyone know what if there is some product that can fix this? I was thinking of something like one of those carbon fiber tach covers because they do extend a little farther than tach cover, and they also look cool. If anyone has any suggestions for this please let me know. Thanks.
Old Jun 12, 2008 | 03:39 PM
paulmasoner's Avatar
Asshole for hire
easiest solution, dont drive with the sunroof open mid-day
Old Jun 12, 2008 | 03:44 PM
jlf12345's Avatar
wheres the fun in that???
Old Jun 12, 2008 | 05:53 PM
mzrx's Avatar
Have you try turning your dimmer switch all the way up? The tach will light up white.
Old Jun 12, 2008 | 05:59 PM
ShinkaTeen's Avatar
space reserved for shirt
your 8 cant outrun sunlight?
Old Jun 12, 2008 | 06:33 PM
Jon316G's Avatar
Grasshopper
+1... he probably has the dimmer blue/red lighted display.
Turn it all the way up until it "clicks" to the bright white display.
I've been running with my sun roof open and the sun hitting it and haven't noticed a visibility issue.
Old Jun 12, 2008 | 07:39 PM
Nopstnz8's Avatar
Nope. I have it on the white display. It is only not able to be seen when sunlight hits it directly. I'm not sure if it is all the way to white, but it is pretty close. Thanks I will try that and see if it helps.
Old Jun 12, 2008 | 08:29 PM
Jon316G's Avatar
Grasshopper
There is no way to adjust the intensity of the white... only the blue/red display.
Once its turned up all the why (and "clicks" to white) you can't turn it anymore.
Old Jun 12, 2008 | 08:43 PM
Shifty Devil's Avatar
Can you see it if you wear polarizing sun glasses?
Old Jun 12, 2008 | 11:10 PM
xsnipersgox's Avatar
One Shot One Kill
make sure ur screen is clean, spanking clean, plus.. who needs to look at that anyway? you should really be able to feel how fast you are going.
Old Jun 13, 2008 | 12:31 AM
Nopstnz8's Avatar
I may be able to, but I normally don't wear sunglasses. I will try it with them and see if it makes a difference.
Old Jun 13, 2008 | 12:33 AM
Nopstnz8's Avatar
Yeah I can feel how fast I am going, but the cops in my area are real ********, so I need to know exactly how fast I'm going.
Old Jun 13, 2008 | 04:23 PM
Nubo's Avatar
Lubricious
Go to the hardware store and get some screening material that they sell for fixing window screens. Get black, and heavy-duty if possible.
Cut it to the exact shape of the dial; maybe just a hair bigger. Press it in place. The heavy duty stuff has a bit of stiffness that will help hold it in place. Or you could even use a little bit of post-it type adhesive.
Each little square of the material will cast a tiny shadow and may give you enough contrast to see the dial. Sounds Ghetto, I know, but it's cheap and you might find it acceptable.
Old Jun 14, 2008 | 02:32 PM
VOODOO8's Avatar
Hermitage Holdout
Some dealer will probably try and void his warranty for the mod. Suggestion #1 - get a hot chick in a bikini to ride shotgun and hold her hand above the instrument panel to block the sunlight. Suggestion #2 - move out of the Sunshine State to other parts of the country where sunlight is only a rumor.
WranglerFan
Nov 5, 2017 09:35 AM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
Brooklynite
NE For Sale/Wanted
Nov 10, 2015 06:42 PM
stickmantijuana
Rotary Swaps
11
Sep 24, 2015 12:47 AM
stickmantijuana
Non-Rotary Swaps
Sep 19, 2015 03:15 PM
