error code p 0355
Old Jun 12, 2008 | 12:38 PM
Mr.&Mrs.Magic's Avatar
error code p 0355
After seafoaming the car last night i got and error code of p 0355 (camshaft A postion sensor). I am assuming it is from the dissconnection of the essentric shaft poistion sensor while cranking the car. Is this normal to anyone? I have the COBB AP and it is telling me to reset the ecu. If i do this and the code clears everything is fine right??
Old Jun 12, 2008 | 10:42 PM
Check the connection.
If you have a problem I'm sure the cel will pop up again.
Old Jun 12, 2008 | 11:32 PM
it will clear the code but it's technically "not fine" if the problem is still there. (ie; something still isn't plugged in properly)
check the connections THEN reset the code. If it comes back, there's still an issue
Shankapotamus3
Mar 14, 2021 03:53 PM
jamespond24
Dec 1, 2015 11:11 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
tommy26Germany
Sep 29, 2015 10:33 AM
