jerk/pause at over 4000 rpm
Old Jun 12, 2008 | 12:34 PM
chrisis's Avatar
as you know i bought my rx8 before 2 weeks.
when i drove it the first few times i notice when i was going over 4000 rpm a small jerk/small pause in all gears. because i was driving in a rough road i thought that it was loosing traction, but after i drove it in the highway and during a redline you can really feel the pause.
i'm thinking it maybe happens when the other 2 ports open and causing this pause, but i need to know if you have the same pause.
its a 6 speed manual.
Old Jun 12, 2008 | 01:30 PM
Bluthusten's Avatar
new or used? any lights indicating an error? did you get an electronic diagnosis?
Old Jun 12, 2008 | 01:33 PM
I guess its a used rx-8 right ?
where do you live ? mileage on the car ? what gas u use? oil weight and when was the last time u change it? Have you ever change your filter/plugs/coils/wires ?
Old Jun 12, 2008 | 01:46 PM
PSTNLSS's Avatar
The Former PSNTLSS
Make sure your not letting go of the clutch too soon
But I'll have problems days that the car doesn't wanna change gears, all I do is just double clutch it and everythings good
Old Jun 12, 2008 | 01:55 PM
xsnipersgox's Avatar
One Shot One Kill
i bet the clutch is worn lol... just one of the possible problem though, plugs, coils, wires all have to be checked. if it bogs as u go higher and higher in rpm, it could be the cat.
heyarnold69's Avatar
Rotary wanabee
this happened to me when i first got the car... the car was sitting for a while before that. I simple let the car warm up... patiently kept it under 3000 rpms with teh headlights adn ac on... then I gunned it and redlined it and kept it over 7k for about 2 min or so... problems solved.... cat was gunked up a bit.
i also sprayed the crap out of my map sensor as well. i recommned both. of course do an oil change as well if you havent already
Old Jun 12, 2008 | 01:59 PM
chrisis's Avatar
i live in cyprus, europe. 42000 km, 98 octane, 10w40(mobil 1 semi synthetic) and i changed it before 1 week with new oil filter. air filter is clean and it has new plugs and wires from x owner with receipts.
NO CHECK ENGINE AND NO LIGHTS.
i don't change gear when is doing it. is doing it in all gears at about 4000 rpm + and is doing always at the same rpm and same pattern.
any ideas?
Old Jun 12, 2008 | 02:05 PM
champi0n's Avatar
usually a worn clutch tends to slip under load, where it would go from say 4500rpm to 4250 and back up, and back down and back up and back down.
Old Jun 12, 2008 | 02:07 PM
chrisis's Avatar
just to make clear.
this <<problem>> happens only ones at the same rpm in all gears. it doesn't happen again after that or before.
is not my daily driver. is only for weekends so maybe sitting for 5 days is giving me this problem???????????
Old Jun 12, 2008 | 02:09 PM
Rotary wanabee
have you gotten the loss of power tsb done? carbon build up?
Old Jun 12, 2008 | 02:10 PM
champi0n's Avatar
so drive in 3rd, step on it, if you're not pulling hard and it feels like its slipping or revving too high for the speed... likely clutch.
dont shift to 4th, but ease off the throttle and do it again..
another test ppl do for clutches is stop, put it in 5th or 6th and see if u can let the clutch out while giving it gas without it stalling.
Old Jun 12, 2008 | 02:15 PM
chrisis's Avatar
no, but redline it 3-5 times a day it should take care that
Old Jun 12, 2008 | 02:17 PM
Renesis07's Avatar
Vtak just kicked in yo!!
sounds like a cat, thats what mine did when my cat went out.
Old Jun 12, 2008 | 02:27 PM
chrisis's Avatar
is pulling hard in all gears with no slipping, but when it gets to 4000 rpm i have this millisecond pause and then continues to pull hard till 9500 rpm.
i gave my car to my girlfriend and she stall it a few times when she forgot to push the clutch and the car wanted to keep going so i pretty sure clutch is ok.
Old Jun 12, 2008 | 02:30 PM
chrisis's Avatar
it has new b magic exhaust system and new cats.
Old Jun 12, 2008 | 09:56 PM
daisuke's Avatar
rotorized!!!
Could be one of the intake valves sticking, run some engine degunker thru there and see what that does, you'll have to run it with the engine at those rpms tho so that it does it's job right.
Old Jun 12, 2008 | 11:27 PM
I think your right. The ports are sticking.
Try driving another RX 8 to confirm.
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
Michael Bryant
Oct 12, 2015 03:07 PM
D13
Oct 1, 2015 07:55 AM
tommy26Germany
Sep 29, 2015 10:33 AM
