Antenna
Old Jun 9, 2008 | 12:47 AM
artcoholic's Avatar
Antenna
Does anyone know how to disconnect the internal antenna?
Old Jun 9, 2008 | 12:57 AM
Jasonawojo's Avatar
You can disconnect it from the radio by simply pulling the antenna plug (far leftmost plug) from the back of it. You'll need to pull the radio part way from the dash to do so.
As for actually disconnecting the antenna itself, I believe it is located under the rear deck, but I'm not sure if it can simply be disconnected/removed.
drebbrnator
Dec 27, 2018 07:02 PM
ErwinN
Sep 23, 2015 09:29 PM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
