View Full Version : car stalls at all times after boost gauge install
gregs
06-08-2008, 01:43 PM
last night i installed my prosport boost gauge and was not getting the boost gauge to read boost, i used the same vacuum line as the bov which is located under the throttle body. so this morning i was looking at the vacuum line and i noticed there was a small one way valve on the line so i removed it and tried again "walah" now i seeing boost but at stops the car stalls and struggles to idle also during driving the car backfires alot too...so what im thinking is to place the vacuum T fitting before the one way valve should this correct my issue? or should i get my boost gauge vacuum source elsewhere?
thanks
greg
09Factor
06-08-2008, 01:58 PM
The "T" should be placed before the One way valve. With the green side of the valve toward the "T" fitting.
mysql
06-08-2008, 01:59 PM
vfad nipple on the bttom of the throttle body is a popular choice. I don't know why you're looking at the back of the intake manifold.
gregs
06-08-2008, 02:39 PM
ok thanks for the info
gregs
06-08-2008, 07:24 PM
ok so i just came back from a drive i moved the one way valve (greddy rs bov,one way valve, t fitting, vacuum port under throttle body) the green is facing the t fitting...car holds better at idle but still struggles to stay on and in between shifts sounds like im getting compressor surge???
gregs
06-08-2008, 09:21 PM
now i disconnected the boost sensor and put everything back to normal and im still getting a rough idle at stops and at times it will stall?? i reversed the one way valve green facing the bov and idle is perfect while coming to a stop but im getting compressor surge??
Razz1
06-08-2008, 11:49 PM
RE-check everything.
slavearm
06-09-2008, 01:02 AM
You have a vacuum leak somewhere would be my guess. Recheck all the lines.
gregs
06-09-2008, 09:52 AM
would a pressure test find if there were a leak?
