Fan on after shut down, how long?
Old Jun 6, 2008 | 09:25 PM
Vasichko's Avatar
Just wondering how long do your fans run after shut down?
Should I sit in the car and let it idle a bit before shutting it off?
Old Jun 6, 2008 | 09:36 PM
expo1's Avatar
He's as bad as Can
It takes as long as it takes. Let the car decide.
Old Jun 6, 2008 | 09:39 PM
Brettus's Avatar
Boosted Kiwi
LOL - nice answer Expo
Old Jun 6, 2008 | 10:53 PM
mmats69's Avatar
93.5 octane
+1. unless its staying on for hours at a time, let it do what it is meant to do
Old Jun 6, 2008 | 11:29 PM
10 minutes.
Old Jun 6, 2008 | 11:38 PM
04RX8man's Avatar
Rotary Powered Countryboy
it will shut off when the motor is cool enough just let it go i let mine go and just go in the apt...if you go out like 2 hours late and it's still on then i would go to a dealer but if it's like a couple minutes you're cool
Old Jun 6, 2008 | 11:41 PM
VolcomStoneX's Avatar
Hi, Let's Make Out
haha, i remember, i was like WTF???? when this first happen, i love my 8
Old Jun 6, 2008 | 11:49 PM
Easy_E1's Avatar
Well down here in the desert it can run for a long time. I park in the garage and it seems like an eternity before it shuts off. 10+ minutes on a regular basis.
Old Jun 6, 2008 | 11:51 PM
Hi, Let's Make Out
^^ same here, its always FKN hot in texas....
Old Jun 7, 2008 | 03:18 AM
juikster's Avatar
Im 8 drifting on a budget
Thats why I did like others did in the forum and went to an oversized aftermarket radiator, went as far as drilling relief holes in the tsat to get the needed water flow thats obviously killing engines time and time again from overheating. wirekit the fans to energize together helps, the hot climate here on the gulf coast sometimes gets brutal unforgiving, thats why I have a backup plan to releive the heat....CO2 cannistered shorts that deploy to cool my ***. heh it works........
Old Jun 7, 2008 | 03:45 AM
Spinning Sushi's Avatar
I <3 Sushi
Well, if you don't like the fan staying on when you shut off your car, go back, turn the ignition to ON (don't start the car) and back off, it'll stop the fan from running.
Old Jun 7, 2008 | 10:20 AM
Socr8tes's Avatar
Not recommended. The fans come on for a reason. Just let them do their job.
Old Jun 7, 2008 | 10:29 AM
fahrfegneugen's Avatar
I have yet to have the fan stay on it has been so cold this year... Some cars do this a lot and other's don't. Our Honda did it like a maniac and our Subaru never does it.
Old Jun 7, 2008 | 12:04 PM
Renesis07's Avatar
Vtak just kicked in yo!!
lol, there should be a sticky about this. Every person new to the 8 freaks out when that fan comes on. Its louder than when the car is running lol.
Old Jun 7, 2008 | 12:30 PM
I freaked out more when Jiffy Lube did my oil and the differential was dripping all over my driveway. They didn't clean up the mess they left behind, I ended up going to the dealer about it too...
Old Jun 7, 2008 | 01:23 PM
New Yorker's Avatar
It's not as unusual as you may think. Occasionally the fan on my Miata—and on my '02 VW GTI—would stay on for a long time, too.
Old Jun 7, 2008 | 01:46 PM
nt5k's Avatar
Doesn't every car made in the last 20 years do this already?
Old Jun 7, 2008 | 01:51 PM
Socket7's Avatar
ಠ_ಠ
I freaked out when you said you took an 8 to jiffy lube period.
Let the fans run they'll turn off. I wouldn't worry until the day they actually do drain your battery and you have to push start it. then I'd get a new battery.
Old Jun 7, 2008 | 02:24 PM
DOMINION's Avatar
I don't buy Kool-Aid
Meh Mine will run for a few minutes
Old Jun 7, 2008 | 03:36 PM
Brettus's Avatar
Boosted Kiwi
the reason they stay on is because there is no water flow past the sensor when the engine is off - not an issue to turn the fans off that way if it annoys you .....
Old Jun 8, 2008 | 01:48 AM
Don't ask, I was 120 mi from home and...
Old Jun 8, 2008 | 02:11 AM
boanjangnararmine's Avatar
Toyo Kogyo => Mazda
From: Los Angeles - Arcadia - Monterey Park - La Jolla
with the mazsport fan mod, it turns on more often while driving so when i shut off it doesnt need to stay on for too long. usually less than 30 seconds even after hard driving.
Old Jun 8, 2008 | 03:54 AM
auzoom's Avatar
Hmmmmmm.........
It was my understanding that the water pump doesnt function if the car is off, therefore the fans coming on is pointless anyway. For this reason, I tend to run my car for a min or so after a hard run, and if I hear my fans on after I switch the car off, I turn it back on. Probably pointless
Old Jun 8, 2008 | 08:53 AM
Huey52's Avatar
Registered Zoom Zoomer
Sitting there idling is just defeating the purpose. As everyone else has said, jut let it do its job - it knows when to shut off.
And yes, most radiator fans have been working this way since the fan belt went the way of the Dodo.
btw: my wife's iMac fan was running at high speed for a long time last night (cool indoor ambient despite our heat wave at the moment), but a simple SMC (ROM) reset did the trick. Horse of a different feather, but related.
Old Jun 8, 2008 | 12:22 PM
kvndoom's Avatar
The Slow and the Serious
Yesterday was the first time I heard mine run. Then again, it did set a new record here yesterday (101, ugh!). Kinda funny because I had just read this thread on Friday. Yeah, it's loud, almost as loud as the engine! Doesn't bother me; just funny to hear.
