Some ?'s
Old Jun 6, 2008 | 12:00 AM
eroc's Avatar
Some ?'s
Hello, I bought a 2005 Shinka with 19,148 miles about a month ago, a few days ago I noticed while at a stop light that my car was a bit shakey, not alot but my previous car didn't shake, I took it to the dealer and the mechanic said in his report that he could not reproduce what I was feeling. Is it normal for the car to be alittle shakey at idle? My breaks began to squeal too, should they fix this or is it normal? Other than that and the gas I LOVE my new used car!!!
Old Jun 6, 2008 | 12:08 AM
hakuna matata!
was the car itself vibrating or just the shifter?
Old Jun 6, 2008 | 12:21 AM
Bumble_Bee's Avatar
"Autobots Roll-Out..!"
Other than your issue.. Congrats and Welcome...! :p
Old Jun 6, 2008 | 12:30 AM
Icemark's Avatar
There is a TSB for the front brakes squealing.
and idle roughness can be a couple of things.
Old Jun 6, 2008 | 01:04 AM
Jon316G's Avatar
Grasshopper
A little shaky is normal. There was a TSB on the motor mounts.
You could ask any dealer to look up the history on what recalls/TSBs were performed on that car and if any are needed.
Since its used, you don't know what has been done (or not done) to it.
Old Jun 7, 2008 | 11:58 PM
eroc's Avatar
The car itself is shaky. Thanks
Old Jun 8, 2008 | 12:00 AM
To be named later's Avatar
Now with 25% more fluff..
what grade gas are you using?
Old Jun 8, 2008 | 12:40 AM
Old Rotor's Avatar
Here is a site with the TSB's you need to read and then print out the ones that will help your dealer find your problems.(#29 & 35 from the top)
http://www.finishlineperformance.com....php?pageid=11
Old Jun 8, 2008 | 03:04 PM
eroc's Avatar
Thanks for your quick responses! I use 91 gas but been reading that 87 is good enough and that the car likes it better? I'll check out those TSB's and showing it to the dealer. Thanks a million!
Old Jun 8, 2008 | 03:57 PM
Jon316G's Avatar
Grasshopper
The car likes the 87 octane better!?
Maybe with MPG.
Old Jun 8, 2008 | 04:39 PM
Old Rotor's Avatar
You can use reg-87 if your engine does not mind it. If you hear the engine making a sound like what we call MIAC(Marbles In A Can) move up to mid grade-89 or 91. The MIAC is the sound that a Rotary makes when it is detonating(PING). It is very bad for a Rotary engine and will damage it quickly. So if you do hear a sound coming from the engine that sounds like a tin can shaken with a marble in it, stop pushing the gas pedal and add some higher octane gas. There are some other simple things(that cost nothing and take five mins) you can do to keep using reg-87.
