Squeaky Brakes!
Old Jun 4, 2008 | 04:04 PM
wankelhead's Avatar
Lotus Wannabe
Squeaky Brakes!
So, I have had my 2004 RX-8 for about 7 months now and absolutely love it! I do however have one complaint - what is with the squeaky brakes???? I asked the service dept to look at them and the guy just chuckled and said "better get used to that". Well, they checked them and they were fine. This is just weird, brakes aren't supposed to do this I don't think. I have read numerous things on the web that talk about this problem with the RX-8s. I am sure this has been discussed in this forum in the past but I don't have the patience to look for the thread, so I started a new one. Has anyone successfully dealt with this?
Old Jun 4, 2008 | 04:20 PM
kersh4w's Avatar
Hit & Run Magnet
better get used to it.
i changed to hawk hps brake pads a few months ago and they started squeaking again...
Old Jun 4, 2008 | 04:22 PM
JTtheDude's Avatar
I'd go back to that guy and slap this in his face
http://www.finishlineperformance.com...01-06-1568.pdf
Or just buy new brakes
Old Jun 4, 2008 | 04:48 PM
Socket7's Avatar
ಠ_ಠ
My brakes squeak once in the mornings when I stop before pulling out of my driveway into the street. never any other time.
Old Jun 4, 2008 | 09:22 PM
vad6's Avatar
Thanks Dude
Purchased my 05 3 months ago...squealing is my only complaint (and well outweighed by all of the rest of the beauty and performance). But I do have the original warranty (car only had 7000 miles when I got it)....is the brake correction covered?
Thanks for the bulletin, I will definitely use it!
Old Jun 4, 2008 | 11:21 PM
ho1ming's Avatar
I got my 05 3 months ago and had the same problem, i brought the bulletin to the dealer and they put new pads on the front breaks, now the car drives like new
Old Jun 4, 2008 | 11:57 PM
DOMINION's Avatar
I don't buy Kool-Aid
+1 and Hawk HPS suck! But I did hear that the blue ones are good. I dont know, I dont want to find out. I'm sticking with MS pads
Old Jun 5, 2008 | 12:05 AM
04RX8man's Avatar
Rotary Powered Countryboy
I have an 04 with stock pads and they used to squeak quite a bit there is like a wierd film almost on the stock pads that cause them to squeak. I took my brakes off and sprayed some brake cleaner and reallly heated them up next time out and they stopped doin it!!! Or change out to different pads that could do the trick too.....the only time mine squeak is when theyare wet but thats with any brake pads pretty much
Old Jun 5, 2008 | 12:49 AM
fahrfegneugen's Avatar
They just squeak. You can clean them and that will help for a while, but if you live in a place like where I do, they will get loud again. The worst thing though is when you get a rock between the rotor and caliper, that is music to the ears...
Old Jun 6, 2008 | 01:10 PM
wankelhead's Avatar
Lotus Wannabe
Dealer told me th bulletin is only good for under 12k miles or 12 months from purchase. Bummer. However, said he would bill Mazda for the parts and just charge me a couple hours of labor. Hmmmm...
Old Jun 6, 2008 | 02:46 PM
rot8tn's Avatar
Rot8tn the 8
feel ur pain my car does the same thing and i just replace new pads
Old Jun 6, 2008 | 02:54 PM
RotaryP7's Avatar
Seriously.. FML..
Same problem.. And I have an 07..
Old Jun 6, 2008 | 03:53 PM
Tim Tim Tim's Avatar
auto suckkssssss
mine didnt squeek when I got it, on my second set of pads and they dont squeek either
Old Jun 6, 2008 | 03:56 PM
Scottyman's Avatar
I have had brake squeal problems for most of the 3.5 years I have had my car. I had new front pads put on by the dealer, tried "Disc Brake Quiet", tried periodically bedding the pads (heating them up coming to fast stop repeatedly), and even bought some cheap front pads at Autozone. Nothing has kept the problem from coming back eventually. The Autozone pads went the longest without squeal (~10K), but they didn't provide nearly as good stopping as the OEM pads and were a little scary in the rain. In fact, I have changed back to the OEM front pads primarily for this reason. Maybe I will get 1000 miles before they start to squeal again . Maybe one day when it is time to change rotors, I can stop it for good.
Old Jun 6, 2008 | 04:05 PM
skhmund's Avatar
THE BITCH IS DEAD
I'm assuming most of yall are having this problem because ur driving is mostly CITY? bc i have a 05' and 56k miles, and im just now getting squeaking noises but thats only after long periods of driving and my drive is mostly HWY
Old Jun 6, 2008 | 04:10 PM
ken-x8's Avatar
I've got an '06, mostly suburban driving, and don't have a squeak problem. In almost two years I might have had 3 or 4 random squeaks, but for the most part the brakes are quiet.
Ken
Old Jun 6, 2008 | 04:44 PM
c0ldf1ame's Avatar
high performance pads = squeaking, get used to it
Old Jun 6, 2008 | 09:12 PM
RotaryP7's Avatar
Seriously.. FML..
^ OEM pads = squeaking too I guess..
Old Jun 6, 2008 | 10:56 PM
YaXMaNGTO's Avatar
It's a Cavalier
You have a great sports car... with some of the best performing OEM brakes on the planet... little squeak from them? BIG SMURFING DEAL. Enjoy your car and forget it.
Old Jun 6, 2008 | 11:00 PM
mmats69's Avatar
93.5 octane
yup...mine did it too. just get use to it
Old Jun 7, 2008 | 10:18 AM
I only worry that people will think I don't take care of my car when I roll up and it is going sqqeeeeek. lol
Old Jun 7, 2008 | 10:51 AM
VampireSix's Avatar
+1. I took my car into the dealer about three times about the squeaky pads within the first few months of owning the car (is an '04, had 48k miles at purchase).
First time they just told me they checked out ok.
Second time they said that rain/moisture was causing it, and it was ok.
Third time they had me take the service manager for a drive to replicate the problem. Then the service manager took me to the parts department and grabbed a new brakepad to have me look at.
The OEM pads have a VERY high metal content when compared to other pads (you could see the metal flakes sparkle). I'm no brake expert, but my understanding is this is part of what makes the pads work so well, and it also just happens to cause a little bit of squeak.
so, in short, everything should be fine.
hufflepuff
May 30, 2016 10:45 AM
Road Cone
Nov 6, 2015 01:52 PM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
