Pics, thoughts: 18x8 +35
Old Jun 4, 2008 | 10:02 AM
savedsol's Avatar
Carbonormous
To fill out the wheel wells a little. BTW, I would love to do a search but you can't search the number 35 or +35 or 35+.
Old Jun 4, 2008 | 10:10 AM
savedsol's Avatar
Carbonormous
Make a post and the "similar threads" can find it. Lame.
Not good looking wheels but 18x8.5 +35 apparently
https://www.rx8club.com/showthread.p...light=ode+tree
Old Jun 4, 2008 | 01:00 PM
rglbegl's Avatar
Baned
Go a little farther to a +38
The fronts are close to what you are looking for(38). The rears are even more aggresive(43)
Old Jun 4, 2008 | 01:32 PM
Aipex8's Avatar
X e p i A
^ The smaller the number, the further from the middle of the car the edge of the wheel is. +35 is more aggressive than +38 or +43 (stock is +50). The reason that your wheels sit more flush is a combonation of offset and wheel width. 18x8 +35 will look fairly aggressive.
Old Jun 4, 2008 | 01:33 PM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
That would be less aggressive than what he is looking at.... The bigger the number the more they stick in. Stock is +50, so a +35 is out of the fender 15mm more than stock. Your +43 is only 7mm away from stock.
Old Jun 4, 2008 | 02:31 PM
rglbegl's Avatar
Baned
I am a wheel noob.
Thank you for clearing that up.
BTW -
The fronts are 8.5" wide, and the rears are 9.5" wide.
I am sure that will make a difference as well.
Old Jun 4, 2008 | 02:40 PM
chrism's Avatar
Misfit Moderator TnC
i have 19x9.5 in the rear with +35 offset....so with an 8.5 you will be an inch farther in than mine
http://i302.photobucket.com/albums/n...g?t=1212608393
Old Jun 4, 2008 | 03:12 PM
kevinD1226's Avatar
im not that good with wheel specs or anything but cant u buy wheel spacers to get the offset ur looking for?
Old Jun 4, 2008 | 03:18 PM
Easy_E1's Avatar
If you started with a 50 mm offset and added a 7 mm spacer you would have a 43 mm off set. Simple as that. A spacer width subtracts from the original offset.
Old Jun 4, 2008 | 03:31 PM
kevinD1226's Avatar
right but how thick of a spacer can u go with the rx8 before u need bigger wheel studs? by installing a spacer does it not take way from the stud the lug nut goes on?
Old Jun 4, 2008 | 04:01 PM
Footman's Avatar
Dodging those Corollas
I too, am also interested in the 18 x 8, +35 setup all around. Looking at the OZ ultralegggeras silver
Old Jun 4, 2008 | 04:55 PM
savedsol's Avatar
Carbonormous
Me too, but black. The +48 that Tire Rack lists for us doesn't interest me.
Old Jun 4, 2008 | 05:03 PM
Aipex8's Avatar
X e p i A
Most spacers 15mm and up have studs built in to them. So you use the cars studs to bolt the spacers on, then bolt the wheel on to the spacers studs. A 25mm spacer will allow the wheel studs to sit flush with the spacer. 15mm and 20mm will leave some of the stock stud sticking out from the spacer so the wheel has to have a cavity on the backside .The stock wheels do have this cavity, although I haven't measured how deep it is. I can check when I get home.
User Creekhail just posted pics of his RX-8 with H&R spacers (although he didn't specify what size they are). They look really good though:
Old Jun 4, 2008 | 05:35 PM
Footman's Avatar
I am still deciding between black or silver finish. I'm getting my brake calipers painted red this week. I have stock rims right now, so I will be able to get a good gauge of how "silver rims + red calipers" will look.
Old Jun 4, 2008 | 06:58 PM
05rex8's Avatar
sold the 8... :(
here's mine with 18x8.5 +35 offset w/225 45 zr 18 tires
Old Jun 5, 2008 | 05:04 PM
altiain's Avatar
Sparky!
Actually, he'll only be half an inch further in than you. Offset is measured from the wheel centerline. If your 9.5" wheel had a zero offset, it would measure 4.75" (9.5"/2) from the hub surface to the outer lip. To factor in offset, subtract the offset from half the wheel width.
9.5" wheel w/ +35mm offset: 9.5"/2 = 4.75" - 1.38" (35mm) offset = 3.37" from lip to hub surface.
8.5" wheel w/ + 35mm offset: 8.5"/2 = 4.25" - 1.38" (35mm) offset = 2.87" from lip to hub surface.
3.37" - 2.87" = .50"
Stock wheel is 8" wide w/ + 50mm offset, so for comparison's sake: 8"/2 = 4" - 1.97" (50mm) = 2.03" from lip to hub surface.
Jst4fun
Apr 17, 2021 07:43 AM
Jst4fun
Mar 5, 2021 07:16 PM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
He||hammer
Sep 29, 2015 09:40 PM
