tenzo r overdose wheels
Old Jun 3, 2008 | 05:55 PM
two zero two's Avatar
Unregistered User
i was thinking about getting a set of these,
but i'm not sure which one will fit closest to the stock wheels.
i want to keep the 18", but i'm not sure on the fittings
the specs are 18x7.5, 5x100 bolt pattern, with 42mm offset or
18x7.5, 5x114.3 bolt pattern, with 42mm offset.
are these roughly the same size as the stock wheels?
would the potenza RE040's i have on my stock wheels right now
fit well onto these?
http://www.breakthrumotorsports.com/...79_4882&page=1
Old Jun 3, 2008 | 05:58 PM
chrism's Avatar
Misfit Moderator TnC
your oems are 18x8 so with those you would be going smaller diminishing your handling
Old Jun 3, 2008 | 06:33 PM
Unregistered User
i'm pretty sure vividracing used to sell them in a 18x8 size, but they took the overdose line off their site a few days ago, i'm still looking around though.
would i need the 5x100 or 5x114.3 bolt pattern?
Old Jun 3, 2008 | 10:34 PM
N rider89's Avatar
^NieL
i would avoid vividracing....
Old Jun 4, 2008 | 03:13 AM
nvrfalter's Avatar
tonybob failpants
you would definitely not want to go any skinnier. im not feelin that style either. the ring in the middle is kinda bush.
Old Jun 4, 2008 | 01:39 PM
Aipex8's Avatar
X e p i A
You need 5x114.3. Don't go with 7.5 wide though, find a wheel that is the 18x8.5 with an offset between +40 and +35.
Old Jun 5, 2008 | 02:03 PM
Unregistered User
ok thank you, i have no idea about wheel fitment or sizes, this is exactly the information i need to shop around, thanks
Old Jun 5, 2008 | 11:55 PM
8 Maniac's Avatar
Senior Member
yeah... I dont really have a whole lot of experience with them but have heard bad stories. I emailed them asking for a quote and a few other questions and it took over a week to respond... I contacted lazi with the same requests and got a response in less than a few hours. Wasn't exactly impressed with that (and the pricing wasn't as good as my other quote...).
I would go no lower than 18x8 or you'll be sacrificing performance (unless looks are all you're going for.
Old Jun 7, 2008 | 11:52 AM
Snakebite202's Avatar
IT Guy
I will second that...
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
duworm
Oct 1, 2015 04:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
