Houston Summer Heat
Old Jun 3, 2008 | 05:02 PM
skhmund's Avatar
THE BITCH IS DEAD
Houston Summer Heat
Here in Houston, it reaches into the mid 90's usually and I've noticed that when I'm driving and I let off the gas pedal, n let it just coast, the air out of the AC isn't AS cold as if I was pushing the gas pedal. So I push the gas pedal and the air becomes colder, I let off the pedal and the air isn't as cold.
any ideas??
Old Jun 9, 2008 | 03:49 AM
DOMINION's Avatar
I don't buy Kool-Aid
Look at the part that shows the man its by the track display. You will see a car with arrows. Put the A/C to cycle the air in your Car and not allow the air from out side in.
Hope that helps.
Old Jun 10, 2008 | 06:50 AM
VOODOO8's Avatar
Hermitage Holdout
Cool
any ideas??
An 05 vintage 8 should not need this older TSB to upgrade the original factory unit, but you might want to read it anyway. Might be that your AC Amplifier is failing.
http://www.finishlineperformance.com...02-04-1338.pdf
Old Jun 18, 2008 | 09:06 AM
skhmund's Avatar
THE BITCH IS DEAD
Thanks for the suggestions,
I'll try the first idea and if that doesn't work, then do I just print out the TSB and take it to the dealer and they will do it and it will be covered under warranty or am I missing something? I don't think that new warranty covers this, but I'm not sure........
cliffkemp
Dec 24, 2024 10:48 AM
mdl0209
May 23, 2019 05:46 PM
XianUnix
Sep 29, 2015 03:48 PM
Learners_Permit
Sep 27, 2015 07:38 PM
