Black stuff on the underside scraped off - bad?
Old Jun 3, 2008 | 09:42 AM
PBlue's Avatar
Dial P for Phantom
I was jacking up the car and when letting it down i slipped and let the valve down too quick and the jack scraped off some of the black ??? stuff that is sprayed on the underside of the car. easiest place to feel it is right behind the front tire. Im not sure if this is a big deal or not. But if its protecting frame steel from corrosion or something I need to get some more to put on. Anyone know what it is or what i should do?
Old Jun 3, 2008 | 09:53 AM
RX8pimp's Avatar
You can get more of it from autozone to respray what you scraped off
it is called undercarriage spray to prevent rust etc
Shouldn't worry about it too much if your in florida - I don't think you guys got enough salt etc on the floor - but I'd respray it just to be safe from rust if you are keeping the car for longer than 3 years
Old Jun 3, 2008 | 11:20 AM
PBlue's Avatar
Dial P for Phantom
Thanks, I will get some. No salt on the roads, but tons in the air.
Old Jun 3, 2008 | 12:35 PM
lilring's Avatar
Finally a MT
its called undercoating.. i think everyone should get it put on once a year. it will pretect the 8 from rusting
WingleBeast
22
May 23, 2016 09:22 PM
Jazzmeson
Aug 30, 2015 02:23 AM
GrAfiX
Aug 24, 2015 08:08 AM
EfrainOlivares
Aug 14, 2015 06:17 PM
Jazzmeson
Aug 2, 2015 09:49 PM
