crazy cel??!!
Old Jun 2, 2008 | 09:43 PM
burtonride0's Avatar
Exclamation crazy cel??!!
What does it mean when your driving your car and the check engine light starts blinking for like 10-20 seconds and the goes away??? This has happened to me about 5 times now!!!
Old Jun 2, 2008 | 09:46 PM
HockeyRX-8's Avatar
TNC
Sounds like a misfire to me.
Old Jun 2, 2008 | 10:00 PM
o really?? well what if the cel stays on after it is done blinking??
Old Jun 2, 2008 | 10:08 PM
c0ldf1ame's Avatar
you should probably go to the dealer
Old Jun 2, 2008 | 10:10 PM
8 Maniac's Avatar
Senior Member
try checking your engine. Go to autozone, they'll tell you what it is for free.
Old Jun 2, 2008 | 10:15 PM
ya alright sounds good!! thanxs
Old Jun 7, 2008 | 12:16 PM
rx8snowboard's Avatar
rx8snowboard
I had the same thing, about 6,000 rpm cel would flash (stayed on after the third time or so) took it to the dealership and they had to replace plugs, wires, and coils... runs fine now.
ps. auto zone could not read the codes but my mechanic and dealership could
Old Jun 8, 2008 | 10:46 AM
bose's Avatar
Reginald P. Billingsly
burtonride where are from?
Old Jun 9, 2008 | 11:01 AM
i live in California.. why?? Where r u from?
Old Jun 9, 2008 | 11:04 AM
change your plugs and coils, its due.
for your question, it is Misfire. When it happens more than once in each drive cycle for 2 drive cycle, after the second blink in the 2nd drive cycle, the CEL will stay lid.
Remember, they might replace plugs for free depends on how *good* the dealership is. Cuz plugs are considered as wear item and should be changed every 30K miles ( I change mine every 15K, coils maybe 20K, just so you know)
For coils, u might have to fight for it, cuz sometimes even when it tests out to be *within* spec, its still not good.
Next time, SEARCH THE SITE BEFORE YOU POST. Your question has been answered like zillion times.
Old Jun 9, 2008 | 11:10 AM
Feras's Avatar
the Doctor
MISFIRE! yeah it sucks, i had a couple of those due to a loose eccentric shaft
Old Jun 9, 2008 | 11:11 AM
Socket7's Avatar
ಠ_ಠ
sounds like a misfire.
What octane gas are you using?
Old Jun 9, 2008 | 09:42 PM
What RPM are you driving at when you get the cels?
We assume high RPM, which then I agree w/nycgps except I would just do the plugs unless you have 50k on the wires, then change them too.
Old Oct 14, 2008 | 03:22 PM
Matt RX8's Avatar
I'm getting a misfire code CEL around 6K RPM. It only gets thrown when my car is on the track all day.
I recently replaced plugs, plug wires and coils and I'm still throwing the CEL.
I'm going to go back to stock exhaust and see if that helps. My car shoots flames with my cat back (Greddy SP2) and I never used to throw CELs when stock.
Any suggestions for what else to try?
Old Oct 15, 2008 | 03:03 PM
Exclamation
alright soo i changed my spark plugs, wires and coil and my cel still keeps going off!!! Its alittle different now because now it starts flashing whenever im in 3rd gear and i rev it all the way to 9k it starts flashing and staying on!!! Does anyone know what that might mean??
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
pjwermuth
Sep 28, 2015 11:36 PM
Evan Gray
Sep 26, 2015 12:30 PM
Forevermore
Sep 20, 2015 01:04 PM
