Engine Problems
Old May 25, 2008 | 02:14 AM
sauceyI986's Avatar
Engine Problems
Well 2nite on as i was pulling away from a stop sign my engine made a weird clunk noise and my check engine light was blinking all over the place then my car dies no power steering nothing all i get when i try to start the car all i get is flames coming out the back just pop pop flames. And Yea if this help i did have a misfire come from cylinder 2 when i checked on friday
Old May 25, 2008 | 08:20 AM
How old are you ?
Search
Old May 25, 2008 | 12:39 PM
fahrfegneugen's Avatar
You got flames? Is the car stock? Do you have a cat?
Old May 25, 2008 | 04:25 PM
sauceyI986's Avatar
im 21 years old if that matters got the car back in 2006 brand new and only have 40,164 miles it
sauceyI986's Avatar
all i have is a midpipe and exhaust
Old May 26, 2008 | 12:10 AM
Have you ever change ur plugs ?
Also, your coil has failed. you are out of warranty so u have to buy a new set. about 100 bux
Old May 26, 2008 | 01:14 PM
sauceyI986's Avatar
no i havnt changed the plugs because i really havnt drove the car till may this is and im getting a bunch of problems with it and. how would i be out of warranty
Old May 26, 2008 | 03:26 PM
sauceyI986's Avatar
ok i check plugs and got the car started, the car sounds like an old lawn more tryin to stay on and all i get is white smoke coming from my exhaust which has a different smell than me just running the mid pipe the car wont even rev and the car runs super ruff.
Old May 26, 2008 | 05:11 PM
Coolant leak?
Old May 26, 2008 | 05:18 PM
snowflakes's Avatar
.DriVeN.
^ how so?
was thinking you got a blown engine.... that was exactly how my shyt died too.. jus bunch of back fires and BLURPBLURP and CLunking.lol..... hopefully not. and if so take ur cat off and all ur Aftermarket crap.
good luck.
Old May 26, 2008 | 05:35 PM
hakuna matata!
oyyy, lawnmower sound = bad.. sounds like a seal probably went...
i would take it into mazda asap, get that midpipe out of there first though..
Old May 26, 2008 | 10:41 PM
sauceyI986's Avatar
yep yep i will be taking my shop early in the morning when the shop opens and hopefully get me a loner car
Old May 26, 2008 | 11:11 PM
you got it at 06 brand new and 40K miles you never changed your plugs ?
I think I see where the problem is : "User abuse"
Well, yours is a 06, bumper to bumper warranty should be over by now. You still have powertrain warranty. put your cat and exhaust back on and bring it to Mazda. You better hope that the dealership will not question you for *have you ever change your plugs*
Your coils might be failing or already failed. Dealership will check it.
P.S. : I dont get it, why people wants to run straight pipes, they love the carbon monoxide or something ?
Old May 26, 2008 | 11:18 PM
hakuna matata!
i think they dont like the cold, global warming ftw!
/sarcasm
Old May 27, 2008 | 01:09 AM
They don't want to afford a new cat... idk
How might that cause a seal failure, the gas isn't burning off and dissolving the oil? Or do you just mean they be looking for any way out of the repair?
^ how so?
I was thinking about the white smoke (water vapor) and water in the engine. I don't really have a clue how that could happen in the rotary though, no head gasket to fail.
Old May 27, 2008 | 06:54 AM
if the seals fail in rotary, coolant can leak.
if the plugs are too old, it might break off and take one of the rotor housing to rotary heaven with it.
Old May 27, 2008 | 10:31 AM
Cool, thanks for the clarification
Old May 28, 2008 | 03:02 AM
sauceyI986's Avatar
here is a clip from my cell phone i took yesterday trying to get it started
http://www.youtube.com/watch?v=D37u34g7BRk
Old May 28, 2008 | 03:18 AM
Spinning Sushi's Avatar
I <3 Sushi
<object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/caCOoHBdXN0"> </param> <embed src="http://www.youtube.com/v/caCOoHBdXN0" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
EDIT: Nevermind, OP fixed the link.
Old May 28, 2008 | 07:59 AM
Thats bad.
I see water ...
Take ur midpipe and exhaust off, bring it to MAzda dealer, u should be still under powertrain warranty, and it should cover ur problem.
Old May 28, 2008 | 10:38 AM
sauceyI986's Avatar
ok an update i drop the car off on Tuesday and now from what i been told i have no compression at all. So they said i need a new motor and now they are trying to see a log or receipts of me doing an oil change on the car which i don't have. I change the oil in my car well before the 3000 mile mark all the time. what to do next?
Old May 30, 2008 | 04:51 PM
snowflakes's Avatar
.DriVeN.
now if your 8's at the dealer and they are looking at ur service records, then jus wait it out and no need to worry if you kept up to date on everything.
if they give you any bullshyt about other shyt and not willing to cover, just go to another dealership and find out if they can do it for you instead. =]
Old May 30, 2008 | 07:32 PM
sauceyI986's Avatar
yea they tried that on me with the service records and b.s. but the only record i have on file is an oil change was back in october 2007 i changed it back in april because the car was sitting since then. it got cleared up because when they checked the miles on the car they seen that only about 3000 something miles were put on the car with in the 6 month time frame
xAgyex
Jun 3, 2026 03:47 PM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
ladnarf1
Apr 29, 2021 11:53 PM
vapor2
Nov 3, 2020 03:38 PM
Belalnabi
Jul 17, 2015 07:48 PM
