amp remote wire problem???
Old May 24, 2008 | 12:28 AM
italianman1987's Avatar
hey guys i am installing my aftermarket amp and subs. i have tapped into all the right wires from the bose amp. the only problem i have is getting the remote wire to work. i have tried several of the 12v cables available, what happens is when i attatch the wire my amp turns on for 2 seconds then turns off again. atleast the led light that shows its powered.
possible wiring problem or amp? it seems like it shorts out and takes a few minutes before it starts up again when i reattatch the wire. help plz thanks
Old May 24, 2008 | 03:14 AM
Socket7's Avatar
ಠ_ಠ
Tap your rear cigarette lighter for an acc signal.
Old May 24, 2008 | 09:39 AM
where would you find the cigarette lighter wire? in the trunk or do i have to tear up the seats to get to it?>
Old May 25, 2008 | 02:37 PM
Socket7's Avatar
ಠ_ಠ
the cigarette lighter wire is attached to the cigarette lighter in the center console. You'll have to pull the center console but its 1 panel held in place by clips and then everything else is held in place by a handful of screws. It lifts right out.
Old May 25, 2008 | 11:00 PM
Vader76's Avatar
I tapped into the bose wire preamp for the remote wire:
Speaker wiring pre Bose Amp.
Left Rear + (Green/Orange)
Left Rear - (Blue/Orange)
Right Rear + (Gray/Red)
Right Rear - (Brown/Red)
Remote Turn on Pink/Black
xAgyex
Jun 3, 2026 03:47 PM
HMSS013
Series I Do It Yourself Forum
Apr 9, 2023 09:13 AM
rotarywanker
Dec 8, 2022 05:56 PM
delicious_dallan
Jan 17, 2020 09:17 AM
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
