Are these Spark Plugs ok???
Old May 23, 2008 | 03:51 AM
DOMINION's Avatar
I don't buy Kool-Aid
Question Are these Spark Plugs ok???
Got a set of Trailing and leading Spark Plugs off Mazsport this week.
http://www.mazsport.net/store/index....duct_list&c=12
When I opened the box I was like ok this dont look right.
Last time I changed my plugs I got them from Mazda and the box's the spark plugs came in where white and had blue printing on the box's and told you where to install them on the Car.
These dont tell you where to install them on your car and the box's are yellow and have NGK in red
The tips of these spark plugs are also different from the ones I got at Mazda. These are cut with a X the spark plugs I got at Mazda had what looked like spikes facing the center of the plugs and thats what the ones I took out of the car looked like. Not like this.
These also have rings on them and have two rings on the Trailing plugs
Take a look at the pics and tell me what you think,
Well I know I can use them cus they screw right in like the OEM ones, but should I use them?
Are they a direct replacement for my OEM plugs? and will I have any problems with them?
Thanks,
-Gil
Old May 23, 2008 | 03:59 AM
MazdaManiac's Avatar
Those are RX-7 plugs.
Most of us use them these days, if for no other reason than they are cheap ($4 - $7 a plug at NAPA).
The trailing need shims because they are too long for the Renesis.
Just remember to cut the wire tie off first!
Old May 23, 2008 | 04:10 AM
DOMINION's Avatar
Angry
Ahhh F**K me, I could have went to AutoZone and got them for dirt cheep
Thanks Jeff...
Old May 23, 2008 | 04:13 AM
DOMINION's Avatar
How long do you think they will last VS the OEM ones?
Old May 23, 2008 | 11:26 AM
Depends on how you drive.
If you don't foul them, they will go for a long time.
That said, I change mine 2 or 3 times a year at least.
Old May 23, 2008 | 05:52 PM
DOMINION's Avatar
Dam it they are not going to last. I drive it like I stole it lol well guess they will do for now till I get a OEM set
Old May 24, 2008 | 03:20 AM
If you drive it like you stole it, the plugs will last for a long time.
Old May 24, 2008 | 07:50 AM
DOMINION's Avatar
Yeah but I have to redline (Freeway redline) her everyday to clean out the carb build up lol
Old Oct 6, 2008 | 06:32 PM
italyhot21's Avatar
Spark Plugs Rx7
Hi guys
i wanna get rx7 spark plugs and put in my 8
but i heard they re bigger so
How much longer r they?
what can i use as a spacer?
Old Oct 6, 2008 | 06:33 PM
how about search or just read this thread more carefully ?
Old Oct 7, 2008 | 01:50 PM
Targatheory's Avatar
The same exact thing happened to me. Mazsport's ebay site is very misleading. I had purchased two trailing "OEM" as advertised, but instead got these rx7. I emailed with a complaint, and all I got was someone saying that I don't know anything about rotaries and that they fit correctly blah blah blah.
That was not what I had complained about...
I was complaining about the false/misleading/insufficient advertising of the plugs...wow
Old Oct 7, 2008 | 02:01 PM
I would not use RX 7 plugs.
The performance is not there and they will foul unless you have a FI car.
Old Oct 7, 2008 | 02:09 PM
Brettus's Avatar
Boosted Kiwi
Oh reary !
guess those other 8's in my rear view mirror were a mirage ........
Old Oct 7, 2008 | 02:44 PM
dozer's Avatar
on his 3rd rx8
Originally Posted by italyhot21
Hi guys
i am sooo confused on this too...not only that can we use both leading and trailing from the rx7 on the 8?
Old Oct 7, 2008 | 03:03 PM
dozer: some FI guys use RX-7 plugs. Not really needed for an NA 8
Old Oct 7, 2008 | 03:06 PM
dozer's Avatar
on his 3rd rx8
so then just forget about it...
Old Oct 7, 2008 | 03:20 PM
plus they're cheap. See MM's response (post #2)
Old Oct 7, 2008 | 04:43 PM
cornholio135's Avatar
SARX
go to www.sparplugs.com
about $ 95 with shipping the Stealership wants anywhere from $170 to over $200
Old Oct 7, 2008 | 05:21 PM
CaptMatt15's Avatar
Run what you Brung
Originally Posted by cornholio135
go to www.sparkplugs.com
I fixed your link, I'm assuming "sparplugs" was not the site you intended
Old Oct 7, 2008 | 08:03 PM
05rex8's Avatar
sold the 8... :(
I use them for my turbo'd 8. You need all trailing ones if you are FI.
Old Oct 7, 2008 | 08:44 PM
Jon316G's Avatar
Grasshopper
I've used the RX7 plugs... but don't expect to get more than 15K miles out of them.
I started getting misfires and ended up just installing new OEM NGK (RX8) plugs.
Old Oct 7, 2008 | 08:47 PM
05rex8's Avatar
sold the 8... :(
you get what you pay for...right?
Old Oct 7, 2008 | 08:55 PM
Jon316G's Avatar
Grasshopper
Absolutely!
Old Oct 8, 2008 | 10:52 AM
olddragger's Avatar
they can be used but they are not quite there for top performance on a na car. who have to use 2 washers on the trailing plug so the tip of the plug doesnt bottom out and on the lead plugs use no washers. AND when you do that you have to retighten them from time to time as they will vibrate loose!
OD
Old Oct 8, 2008 | 01:13 PM
Jon316G's Avatar
Grasshopper
^Absolutely!
And the two trailing plugs SHOULD come with the washers if purchased through MazSport... but its always good to verify!
