June Fastrack posted (RX-8 to STX?!)
Old May 21, 2008 | 07:54 PM
chiketkd's Avatar
Row faster, I hear banjos
Full: http://www.scca.com/documents/Fastra...track-june.pdf
Solo: http://www.scca.com/documents/Fastra...-june-solo.pdf
• The STAC is seeking member feedback on the following listing change proposal: Remove the Mazda RX-8 from the STX exclusion list (ref. 08-056).
Thoughts?
Old May 21, 2008 | 08:35 PM
NeoTuri's Avatar
Dunno. I wouldn't think an Rx8 could make STi power in STU trim.
Old May 21, 2008 | 08:43 PM
you'll just be on 8" wheels and 245 tires instead
it will be hard to put the power down if you get the engine output to it's capability
my advice would be to not over-spring the car and over-lower the car, you'll need compliance to not overload the tires and this will require suspension travel to avoid bottoming out the rear shocks if you can get it hooked up
Old May 21, 2008 | 08:46 PM
chiketkd's Avatar
Power-wise, STi's and Evo's can make ~300whp/330wtq in STU trim. IIRC, Sipe made 220whp/160wtq in his former STU RX-8.
2.0L STX WRXs make ~220-230whp (and a similar amount of wtq) in STX trim, which is a much better match for the RX-8 imho. I doubt the RX-8 would upset the applecart in the STX class, but a well-prepped and well-driven car could possibly trophy in the class at Nats.
Very good point and my feeling as well.
Old May 21, 2008 | 08:49 PM
there have been a few events where STX thumped STU
AWD represents a significant advantage with slippery tires and/or surface
Old May 22, 2008 | 01:18 AM
ratt_finkel's Avatar
Bass Boat Green
It's about time.
Now they just need to restructure the tire and wheel limitations.
Old May 22, 2008 | 08:00 AM
chiketkd's Avatar
Originally Posted by ratt_finkel
It's about time.
+1 Sent my letter in last night.
Old May 22, 2008 | 09:21 AM
chiketkd's Avatar
I just got my log book #.
Old May 23, 2008 | 09:22 AM
altiain's Avatar
Sparky!
Buetzer has thumped SS with a CS Miata more than once. So what?
Given equal prep levels, run conditions, and driver skill STU should always be faster than STX. After all, the top STU car is the exact same platform as the top STX car, but with more power, more torque, better throttle response, wider contact patches and a better drivetrain.
I doubt the RX-8 will be a dominant force in STX, but I think it has a much better shot there than it does in STU.
Old May 23, 2008 | 02:30 PM
Thanks for answering your own question.
The difference is apples vs oranges (SS vs CS) rather than fuji apples vs red delicious apples (STX vs STU)
IMO it won't have any better shot there unless there's no real competition
Old May 23, 2008 | 07:38 PM
I think Bag Man is right.
Old May 23, 2008 | 08:54 PM
shinronin's Avatar
letter sent and logged.
re: real competition in STX cy lee and chris shenefield have moved from STS to STX in cy's civic and are gonna blow up the spot. prepare for some fireworks at nationals. ;-)
Old May 23, 2008 | 09:17 PM
chiketkd's Avatar
Is it a true STX civic? i.e. does it have an lsd?
Old May 23, 2008 | 09:32 PM
moxnix's Avatar
Yes.
Old Jul 23, 2008 | 02:11 PM
chiketkd's Avatar
From the August Fastrack...
On page 18...
Separately from the above cleanup changes, the STAC has recommended that the following proposals be passed along to the BOD:
o In Appendix A, Street Touring Class U, remove the line under “Excluded” which reads “BMW M3 (E46 ‘01+)” (ref.07-001)
o In 14.12.3, under STX (also affects STU), change the last portion to read “…forced induction (turbo(s) or supercharger(s))”
o Change 14.12.4, under STX, to read: “Rim restriction: maximum width of 9 inches, diameter/offset unrestricted. Tire restriction: max width 265mm for FWD/RWD cars.”
o In 14.12.9, remove Mazda RX-8 from the list of excluded cars. (ref. 08-056)
http://www.scca.com/documents/Fastra...k-aug-solo.pdf
Old Jul 23, 2008 | 04:36 PM
fastmike's Avatar
As a SCCA member, I am leery of this proposal especially since STX cars might get wider rims and tires for the FWD and RWD cars.
FM
Old Jul 23, 2008 | 05:23 PM
chiketkd's Avatar
FM
+1 I'm in full support of the RX-8 being moved to STX and the E46 M3 going to STU -- however, I don't feel the tire width increases should take place at the same time. Give it at least one season to see if the competitive balance changes in any way...
Old Jul 23, 2008 | 06:05 PM
it doesn't stand a chance on 8" wheels and 245 tires
Old Jul 23, 2008 | 07:16 PM
fastmike's Avatar
Maybe not at Pro's but I think the 8 would do just fine(or better than fine) with 245 "street" tires at Solo events against the STX top dogs.
FM
Old Jul 24, 2008 | 03:09 PM
it's one thing to think something, it's another to actually have the experience to back it up ....
Old Jul 24, 2008 | 07:51 PM
fastmike's Avatar
I have autox'd street tired RX8's to know how fast they are...And that is before any of the cool ST stuff gets done.
FM
Old Jul 25, 2008 | 03:34 PM
BRODA's Avatar
Not yet famous
+1
The majority of people in this thread agree the RX8 will have a difficult time in STX and that AWD cars have an advantage on certain courses. Why are those same people opposed to allowing wider tires on 2WD cars?
Old Jul 25, 2008 | 07:09 PM
chiketkd's Avatar
Because the BMW's will gain the most from the tire width increase. Besides, the RX-8's true potential in ST* is still a relative unknown.
Hopefully a buddy of mine who's a national champion in ST*, will pick one up if the RX-8 gets classed in STX. That would be a true data point.
-Chike
Old Jul 25, 2008 | 11:03 PM
shinronin's Avatar
it's pretty well known to some.
who dat?
Old Jul 25, 2008 | 11:54 PM
chiketkd's Avatar
Well I know you and a few others that run/ran RX-8s in STU locally, and obviously Sipe's effort is well documented on this board - but until you put a top driver in a well-sorted car, who knows just how well it could do nationally.
who dat?
This person posts on this board from time to time. I'll let them break the news if they so wish...
