View Full Version : What is that ticking noise???
Queen of Mean 05-19-2008, 09:08 PM I just noticed 2 days ago that when I start my car it has some kinda ticking noise coming from the motor or somewhere up there? I have no idea what the hell it is and since I'm a girl I NEED assistance!! I have 42,000 miles, up to date with maint., and I can't tell a diff. in the way it drives or anything else.:banghead:
DarkBrew 05-19-2008, 09:14 PM http://www.youtube.com/watch?v=Tx1XIm6q4r4
Post a video or recording.
BTW, don't pull the "I'm a girl' thing; Just ask for help!
Jon316G 05-19-2008, 09:28 PM Could be several solenoids and valves that perform a self-test when the ignition is first turned on.
Also, check the spark plug wires, at the plugs and at the coils. Could be a spark jumping the gaps.
Queen of Mean 05-19-2008, 09:39 PM The ticking stays on after the car is running and sounds like a lifter noise on a regular engine. Could bad gas make this happen.
xsnipersgox 05-19-2008, 09:53 PM http://www.youtube.com/watch?v=wiI7-iXQj48
tat is wat a bad connection at the spark plug sounds like.
Queen of Mean 05-19-2008, 10:00 PM So if the spark plug wire is loose it'll make that noise??
xsnipersgox 05-19-2008, 10:04 PM if anything from the wire to the sparkplug to the spark plug not properly tighten/loose, you will hear arcing sound.
Jon316G 05-19-2008, 10:09 PM Correct.
Just grab the spark plug wire boots and give it a twist while pushing in and see if you still hear that sound afterwards.
Queen of Mean 05-19-2008, 10:11 PM I found the problem!!! It was the plug wire, it was almost off. I also want to know is it common for them to get that loose? This "dumb" girl fixed something!!:rock:
Jon316G 05-19-2008, 10:11 PM Good job!
Yeah... they have been known to come loose.
If the wires are properly snapped onto the plugs (you can feel it snap), they should not come off--ever. Well, almost never.:)
Jon316G 05-20-2008, 08:53 AM From what I've read here, the lower front plug wire is known to come off.
Queen of Mean 05-20-2008, 11:44 AM well, that's the one that was almost off... gotta change em out anyway so maybe that'll be the end of all this???
VampireSix 05-20-2008, 02:01 PM Well I'm glad someone posted this thread, because I've had this issue since I bought the car a year ago (48k at purchase, 67k now)!
What do I need to do to check my plugs? Does this require taking off the front driver side wheel, or can I check it from the hood?
Jon316G 05-20-2008, 08:40 PM What do I need to do to check my plugs? Does this require taking off the front driver side wheel, or can I check it from the hood?
The plug wires can be checked through the hood if you have long skinny arms.
I just lay on the ground and reach up from underneath.
To check/remove the spark plugs themselves, refer to this DIY:
http://www.rx8club.com/showthread.php?t=145045&highlight=spark
kellyrx8 03-18-2009, 12:00 AM http://www.youtube.com/watch?v=wiI7-iXQj48
thats exactly what mine sounds like...
I took mine to Firestone where my old roommate works, threw it on the lift and checked the wires...everything was snug...
you mentioned in your video that the plug wasnt torqued down enough...did re-torquing it fix the problem?
Razz1 03-18-2009, 11:51 AM Yee Haw! Queen of Mean can be my mechanic any day!
dozer 03-18-2009, 11:54 AM NICE JOB!, now go and link this to every "ticking noise" thread out there...this is EXACTLY what i tell people and they dont wanna believe me
DOMINION 03-22-2009, 07:14 AM That might be due to the fact that I changed my coils spark plugs and spark plug wires and I got, never had, this "ticking noise". I also just went down to my car, removed all the spark plug wires and reinstalled them. Start the car up and its still ticking like timex lol
