TPMS light wont go out after taking my wheels off
Old May 19, 2008 | 05:54 PM
rxracer208's Avatar
I just recently took all of my oem wheels off to paint my calipers and after i put them back on the tpms light wont go out. is there something i need to do when i put the wheels back on or what may the problem be, thanks
Old May 20, 2008 | 03:39 AM
hercmafia's Avatar
check the tire pressure!
Old May 20, 2008 | 05:38 AM
Flashwing's Avatar
3-wheeler
Yep, check the pressure. I've found anything below 31 to 30 PSI in the tires pisses the TPMS off.
I had a valve stem break during a swap of my tires and so I will probably remove the TPMS on my other wheels with my new set of tires. I get the blinking light all the time now.
If the pressure is good and it's still solid you could have a damaged unit. I bet that will be your fix though.
Old May 20, 2008 | 11:31 AM
rxracer208's Avatar
Hey thanks i have checked my tire pressure before and it was good so i will check it afain and if its still good im gonna say screw it bc i have new wheels and tires on the way
Old May 21, 2008 | 02:19 AM
maybe read the owners manual.
silly i know but the answer is in it.
Old May 21, 2008 | 02:32 AM
BoosTED's Avatar
Turn the key on to the run position for 5 seconds then off.
Wait for 15 minutes.
Drive the car at speeds of at least 12 MPH for several minutes. This will register the TPMS code to your ECU.
If this is not done then the flashing TPMS light and beeping will occur.
Flashing light and beeping says that there is a TPMS system malfunction.
Illuminated light means the pressure is too low or high in at least one wheel.
Old May 21, 2008 | 02:36 AM
Easy_E1's Avatar
Illuminated constant light means the TPMS' are not in the wheels. Like mine.
michaelsk8er
Nov 9, 2015 07:06 AM
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
ShadowDragon78
Aug 21, 2015 03:29 PM
mesaboogie
Aug 7, 2015 10:48 AM
