Redlin on the 2009 RX-8
Old May 16, 2008 | 07:32 PM
DOMINION's Avatar
I don't buy Kool-Aid
Question Redlin on the 2009 RX-8
Can someone tell me why it starts at 5K?
Old May 16, 2008 | 07:38 PM
Earl the Pearl's Avatar
From what I have read, the rev limiter is only there until the engine warms up.
Old May 16, 2008 | 07:45 PM
DOMINION's Avatar
Just looks odd in 3 sections then its there at 8.5K odd.
Old May 16, 2008 | 07:48 PM
Ajax's Avatar
it's true that it's a variable redline. Once the engine is warm, it goes to the normal redline of 8500.
I didn't realize it was going to go all the way down to 5.5k either. The only pictures I had seen had it somewhere between 7 and 8k.
Old May 16, 2008 | 07:51 PM
superglue's Avatar
n00b post whore
Yup, those red bars indicate how high you should rev until the engine is fully warmed up. Once the engine begins to warm up, the red blocks turn off in sequence until it's fully warm and they vanish.
Old May 16, 2008 | 07:53 PM
Ajax's Avatar
Isn't it more analog than that? Or at least more sampled, if you know what i mean?
The early shots we saw didn't have the big blocks of red turned completely off, but each little segment can go on and off.. I'm not sure what it's really like, but i think it'll be more gradual than just a big block turning off.
superglue's Avatar
n00b post whore
Also, not a fan of the missing oil pressure gauge and the continuation of the 1976 calculator LED style display on the center console.
Old May 16, 2008 | 07:55 PM
superglue's Avatar
n00b post whore
Uhm, maybe I worded it wrong. I meant to say the same thing you said. I guess what I wrote can be misleading?
Old May 16, 2008 | 10:16 PM
jdoo's Avatar
Well the current oil gauge is useless so I wouldn't miss it, but I agree on the LED center console. That thing is so damn ugly. Easily my least favorite part of my car.
Old May 16, 2008 | 10:34 PM
AJ's Shinka's Avatar
Enthusiast
warmup
Old May 16, 2008 | 11:05 PM
Where is the oil pressure gauge ?
Old May 16, 2008 | 11:07 PM
yushinrt's Avatar
they don't have a oil pressure gauge,who need oil pressure gauge any way the standed ones are designed so it doesn't move as much is it should be
Old May 17, 2008 | 01:24 AM
HEYUSXY's Avatar
White Water Pearl RX-8
I guess probably being one of the few people to actually drive this car already, it wont actually let you go above that red line. It's actually a limiter not a guideline.
Old May 17, 2008 | 01:43 AM
77mjd's Avatar
^^^Since you've driven one, do the different gear ratios give you any different feel at all?
Old May 17, 2008 | 01:51 AM
delhi's Avatar
Grand Chancellor
This variable redline seems to indicate that 10k rpm is available once the last block disappears.
Old May 17, 2008 | 03:11 AM
tiltmode43's Avatar
OMGITM!
Just noticed how reverse is in a different spot...
Old May 17, 2008 | 03:16 AM
DOMINION's Avatar
Cool
Ahh I see. Wow, Its just like my frinds LT. When the car is cold you can only rev it to 3K or 5K RPMs I cant recall but yeah thats cool. This way you cant kill the C.A.T. by driving the car cold
Old May 17, 2008 | 03:17 AM
Detrich's Avatar
幹他媽!
that is one FUGLY steering wheel.
Old May 17, 2008 | 03:18 AM
Enthusiast
How long did it take to get it past the limiter and into redline country? I don't redline until my car is fully warmed up but I'm wondering if I should wait longer.
I believe it is using the MX5 transmission.
Old May 17, 2008 | 03:37 AM
DOMINION's Avatar
Look like the MX-5 and Evo10 steering wheel too
You might. I do.
Yeah thats the one that everyone was saying is stronger than our MT right now. Guess time will tell.
Old May 17, 2008 | 10:00 AM
HEYUSXY's Avatar
'04 winning blue, Grand Touring, 6MT, rear spoiler, rotary accents, 2nd engine
It actually took me a little bit to get used to, but not to much of a different feel. The biggest difference was the sound of the engine. It sounds more agressive, stock.
To be honest with you i've driven this car about four or five times and it just depended on how warm or cold it was outside at the time I started it up. It seemed to warm up completely about five minutes after starting it up.
Old May 17, 2008 | 11:50 AM
foo77's Avatar
4th batch : Apr 03'
you can see in the Performance here
http://www.autoblog.com/2008/03/10/u...sale-in-japan/
Old May 19, 2008 | 12:11 PM
JRichter's Avatar
Void Where Prohibited
For those that don't know (I wouldn't recommend trying to find out!), the current (or at least my '05) RX-8 will cut your fuel if you try to rev beyond 4-5k when it's really cold as was discussed in a previous thread. It just doesn't have the red limiter lights like the new one. Don't ask me how I found this out.
Old Jul 18, 2008 | 08:30 AM
SWSDuvall's Avatar
Redlining
Hi all,
Check out my thread on my new '09
https://www.rx8club.com/rx-8-discussion-3/ive-got-2009-rx-8-gt-148308/
As to the variable red line:
On cold start it takes less than 1 mile or about 3 minutes for the first segment to disappear - just as the temp gauge barely starts to more off the detent. The last segment doesn't disappear until the temp gauge is about 1/3 scale (1/2 scale if normal op temp).
I ....gently.... if that's possible tested the 2nd segment red line and it does do a fuel cut out about 1/3 the way into the bar segment.
Steve
Old Jul 23, 2008 | 10:02 PM
TheWulf's Avatar
My 8 looks like a Smurf
That gauge doesn't even work... wasted real estate! Give me something useful instead, like mileage calculations.
Strange.. mine doesn't do that... 06 GT. (not that I make it a habit but I have done it on occasion)
